Question about Texas Instruments TI-89 Calculator
Graphing How do I change the graphing function to be 3D
  • Anonymous Dec 17, 2008
    i cant see my x or y axis when i graph..what do i do?
  • 3,037 Answers
Go to the mode section and it will be the first option, you need to click on the mode button
Posted on Mar 31, 2008
SOURCE:
How to graphing regarding ohter axes?
Add a graph .
In Documents Toolbox, select 3: Graph/Entry Edit
Unfold the menu and select Equation (not function). Enter your equation.
For the 3D part, I am afraid you will have to read the manual.
Jan 22, 2016 | Texas Instruments TI-Nspire CX CAS...
How can you graph a spherical shape when z axis is predeined as z(x,y) ?
You need to set the graphing mode to 3D. In 3D graphing the function is represented as z(x,y)=function of the variables x and y.
Here are a few screen capture to show you how to set the thing up.
Read the calculator manual.
On the last screen are the parameters to change the point of view.
Aug 29, 2014 | Texas Instruments TI-92 Plus Calculator
I need an activation cod for graphing calculator 3d 3.2
hi, you can purchase from http://calculator.runiter.com/graphing-calculator/buy-graphing-calculator.htm
let me know if it works.
May 12, 2011 | Computers & Internet
Hi, I wonder how to use a TI89 to graph a multivariable functions's 3D picture. Thanks.
First you must configure your calculator to perform 3D graphics
Press MODE
1.The first line shown is Graph. Unfold the hidden menu list with the right arrow and choose Graph 5:3D
2. Press ENTER to validate.
Now you must define the surface you want to draw
1. Press the [diamond] key then [Y=] to get a list of function names, the first of which is z1
2. Enter the following function (or your own) z1=(x^3*y-y^3*x)/390
( x cubed times y -y cubed times x) divided by 390.
3 Press ENTER.
Graph the function
Press the [diamond] key then [GRAPH]
The graphing screen displays progress in %. When it is finished you will see a weird sombrero.
Hope it helps
Mar 21, 2011 | Texas Instruments TI-89 Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
How do I do 3D graphs on a TI-89?
Press MODE
1. Press the [diamond] key then [Y=] to get a list of function names, the first of wich is z1
3 Press ENTER.
Graph the function
The graphing screen displays progess in %. When it is finished you will see a weird sombrero.
Hope it helps
Jul 18, 2009 | Texas Instruments TI-89 Calculator
Deleting the 3D function
I heard of instructor disabiling APPS but, not functions. One reason I can't see that is I can download a program that does the same thing and hide it w/ instructor even knowing its there unless he ran a search in ever folder or open a lot of programs
Mar 24, 2009 | Texas Instruments TI-89 Calculator
I cannot plot graph in my Ti 89 graphing calculator
That means one (or more) of the variables you have in your function is not defined. Check to make sure you didn't misspell any variable name. Also, check to make sure you didn't run two variable names together. "ab" is the variable ab, not a times b.
Mar 19, 2009 | Texas Instruments TI-84 Plus Calculator
How to graph linear equation in two variables
I am not quite sure what you are asking...
(1) if asking for graphing y= -2/3x+2, then press [diamond] [F1: Y=] type in .2/3x +2, see graph by [diamond][graph]
(2) if asking for graphing y= -2/3x+a, where a=3x, then first archive a=3x in Home screen by [home], type 3x [sto] a, then go back to y= menu, and type -2/3x+a in Y1
(3) if asking for graphing an equation that is dependent on 2 variables at the same time, use x-y-z axis (aka, change mode to graphing 3-D by [mode]graph [5:3D]) then enter desired equation in y= menu using Z function in terms of x and y aka z(x,y)= ...)
May 18, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
59 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
