Whirlpool washer top load agitator does not work
Whirlpool washer top load agitator does not work. The tub fills with water but no movement from the agitator. I cleaned out the lint from the agitator but do not know what to do further. Please help.
  • 343 Answers
Whirlpool top load machines have a coupling beyween the motor and the gearbox..This coupling can fail with age or if the machine is overloaded. The pump should still work even if the coupling is broken..If this is the case then it's not a big job...You need a tech who knows the tricks, and it won't take long to fix....Good luck....Nomess
Posted on May 16, 2010
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer wont stop filling with water it will run over into floor it will agitate but water keeps running . it is a whirlpoot top loading.
you nead to check the plastic hose from the water leval switch to thbe outer tub.if line is good than you have a bad water leval switch.
Oct 29, 2009 | Whirlpool LSR5132PQ Top Load Washer
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
May 30, 2009 | Whirlpool AWZ412 Front Load Washer
Why washer will not fill with water
you either have a bad load level switch or the hose from the switch to the tub is clogged
Mar 20, 2009 | Whirlpool LSR5132PQ Top Load Washer
Won't agitate
the lid switch is bad but a new one and replace it and you will be washing again
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Nov 02, 2007 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
