Question about SanDisk Sansa m250 MP3 Player
"Not enough space for Music DB. Please Free 4MB"
I've had my player since June, and i've always use WMP to sync music files onto it. A couple days ago, i tried to add two new songs. It seemed to work, but then when i disconnected it and turned it on, it said "No Files." So i reconnected to the PC, but the device wouldn't show up. It makes the device connection sound, but it doesn't show up under My Computer, the disconnect device icon doesn't show up, and WMP doesn't recognize that it's there. So i unplugged it again, turned it on again, and now it gives me a message when it turns on: "Not enough space for Music DB. Please Free 4MB" It shows this message for a couple seconds, then goes to the playing screen, which still says "No Files." So I can't reformat or delete anything, because it doesn't show up anymore on my PC. And I can't change any settings, because if i press the menu button, it displays the message again. i was trying to charge my player and add songs and after i disconnected and tried to turn on player, it read "not enough space on music DB. Please free 4 MB"
  • Anonymous Apr 05, 2008
    same
  • Markkw Apr 25, 2008
    I have the same problem with my new Sansa m250 only with mp3 files.
    Information shows I have 759 mB available of the 1.9 GB total. Have 575 tracks loaded (somehow ended up with 2 to 3 multiples of the same tracks) but cannot see my USB connection with my sansa any more.
    When I plug in the player to my usb port the player reads "USB Connected" and "MIP".
  • 8,596 Answers
Corrupt database - upgrade the firmware from www.sandisk.com
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
SOURCE:
Please free 4mb
hello sir
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Mar 29, 2010 | SanDisk Sansa c200 MP3 Player
Sansa m230
When connected to your computer, go to your My Computer folder, and right click on your Mp3 player. You should see "Format Device". This wipes the entire thing. All music will be gone, but it might reset it.
Jun 02, 2009 | SanDisk Sansa m230 MP3 Player
Not enough space for music DB. Please free 90MB
Remove the microSD card and then delete one or more files from the Sansa's internal memory to free up an additional 90MB.
Oct 29, 2008 | SanDisk Sansa Fuze MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Not enough room for music database please free 4 mb
The device needs at least 4MB of free space.
You need to keep deleting files until there is 4MB less than the total capacity of the device.
Its not syncing because the device is too full.
If removing the 4MB doesnt work. Try formatting the device thru My Computer>Device Name (m200)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
we had that problem and sandisk had us use a file when we plugged it in to our computer to reformat it but I don't remember how exactly how to do it, seems like we connected it and chose a file -sorry
Feb 22, 2007 | SanDisk Sansa m230 MP3 Player
I dont know what the problem is
Hi I am not an expert by any means, but when I had issues with my M250, I went to the Sansa site and downloaded the latest firmware onto the M250 and my problems disappeared. Good luck
Feb 11, 2007 | SanDisk Sansa m250 MP3 Player
My sansa m250 says "not enough space for Music DB Please Free 8MB".. when...
I received the same problem, I thought I had done a Sync by mistake and had used of all the space. I had to re-format the player and start over.
Jan 27, 2007 | SanDisk Sansa m250 MP3 Player
I need help please help me
DB corruption - see my Sansa Tips and tricks
Nov 22, 2006 | SanDisk Sansa m230 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
164 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
