Question about Dryers
I replaced the glowbar and it still won't heat up
    President:
  • 1,430 Answers
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on May 16, 2010
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
The oven comes on but won't heat up
Replace the glowbar ignitor. Remove the oven racks and then the bottom base pan in the oven to access the glowbar ignitor.
If you have a volt/amp meter place the clamp on amp meter over one wire of the ignitor.Turn the oven on. If it reads less than 3 amps,replace the ignitor.
Nov 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
My Gas stove takes over an hour to preheat sometimes.
Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps.
Jul 25, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
GE SPECTRA JGBP35 Gas oven
Solved a similar issue. Sounds like your glowbar igniter is shot and needs to be replaced. While the glowbar is glowing, it is not heating up sufficiently to release gas into the oven. The heat you feel in the oven is actually from the glowbar and not from ignited gas. Replace the glowbard. Here is what I recommended to someone else:
"Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps."
Jun 24, 2009 | GE Spectra JGBP35 Gas Kitchen Range
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Jun 22, 2009 | Maytag Dryers
No gas getting to oven or broiler stovetop works glow plugs work on oven and broiler recently move applianc for cleaning took warmer drawer out and vaccuumed in there thought maybe i loosened a wire cannot...
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
May 17, 2009 | Kitchen Ranges
Does not heat up,gas not turning on.
does the unit have a glow bar or spark igniter?
If it is the glowbar then I would start of by changing the glowbar.
Mar 10, 2009 | Ovens
Dryers Logo
42 people viewed this question
Top Dryers Experts
