Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Kitchenaid dishwasher Fills with water, goes through all cycles but doesn't wash. Water stays in the bottom not draining.
  • Anonymous Mar 23, 2014
    Kitchenaid KUDS01 begins normal wash cycle then gets stuck after 4 or 5 minutes, makes a buzzing noise and will not finish. The wash fills and water is hot. The 2 minutes drain cycle works.
    Novelist:
  • 161 Answers
Motor bad. If you are getting power to the motor then the motor is bad.
Posted on Dec 16, 2008
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Apr 17, 2014 | Dishwashers
Dishwasher not cleaning
Remove the panel at the base of unit below door you should find the tech sheet which will tell you how to place unit into diagnostic, on the spray arms make sure the small holes are clean below the lower spray arm is a screen make sure it is clean not covered or cake with calcium build up if it clogged water cannot pass thru to enter the wash pump you can also remove the screws to take the upper halve apart to inspect the wash pump for any obstruction it is possible you could have a bad motor control or both you didn't mention after the unit fills do you hear the wash pump hum or click
Feb 07, 2014 | KitchenAid 24 in. KUDK02CRBS Stainless...
Kenmore dishwasher water will not stay in there
It sounds like you have a drain hose problem. The drain hose needs to have a rise in it. If it is going down hill or to a drain that is lower than the tub it can drain as fast as it fills.
Apr 24, 2010 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Bottom fills with water, line not clogged
This means that the outlet valve or the drain motor is faulty or their is a leak in the pipe between them and the machine.
Sep 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Only motor goes on, no water
Hi,,
try these
  1. Check that the water supply is turned on. The valve may be located under the sink.
  2. Check the door latch
  3. Test the door switch
  4. Inspect the float assembly
  5. Inspect the fill tube for kinks
  6. Test the float switch
  7. Check the inlet valve filter screens
  8. Test the water inlet valve
  9. Test the drain valve lever arm
  10. Check the drain valve
  • please rate my suggestion....
Apr 11, 2009 | KitchenAid Dishwashers
Dishwasher will not go thru wash cycles
doy you hear any sound from either in the wash cycle
Feb 11, 2008 | Dishwashers
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
161 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
