Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
How do you re-initialise a drive, leaving data intact?
How do you re-initialize a drive without formatting? ( i.e just create the descriptor and leave data intact ). My two sata drives are displaying 'unallocated' state but any attempt to reinitialise them prompts me to partition the drives. They were perfectly healthy before I switched my bios to raid mode. After realising my mistake I switched back but drives seem to have lost their 'descriptors'. Previously both drives were ntfs formatted to their maximum partition size.
  • Western Digital Master
  • 9,783 Answers
You're gonna have to reformat them to get rid of the raid information that Bios placed on them.
Posted on Aug 16, 2017
2 Suggested Answers
  • 121 Answers
SOURCE: How do you re-initialise a drive, leaving data intact?
This is highly risky and i would not use it without fully backing up every bit of data on the drives, you most likely will lose the data if you try this!!!! Boot from a downloaded Gparted disc then resize one of the discs by a tiny amount, then apply the changes. This might reset it characteristics to something usuable. If the data is not accessible you could try using "pcinspector filerecovery", its a free download, then when all is rescued, format the drives.
Posted on Mar 23, 2010
Testimonial: "Thanks. I fixed my drives by just undeleting their patitions. I would highly recomend TestDisc & pcinspector for doing this operation. Thanks again. "
The sata disc is not initialised
In Windows? - New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, assigning logical drives, and formatting. If this seems a little daunting. A wizard should load. If not there is refresh icon on the toolbar.
Oct 16, 2012 | Jetway J7f5m Via 1.5ghz Mini Itx With...
Formatteren
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, assigning logical drives, formatting. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar.
Aug 30, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
Mar 23, 2010 | Western Digital Caviar SE WD1600AAJS 160...
I formatted the c drive with an xp disk, but it is corrupt and will not allow me to reinstall xp pro, how do I get to the partition that has the factory OS so I can reinstall it
Try deleting the partition and then create a new partition on the unallocated space, then perform a clean install of win xp onto it if you want to fix corrupted partition issue. If you want to recover data from your previous partition, you have to use third party utilities. First select another partition from your hard drive, format it (if it mayn't contain important data), if it contains important data select leave the partition intact from the XP setup menu. After setup download a software names "Active file Recovery", use it to recover your previous c drive, and you are done, if you face xtra probs mail me to: gktareq2008@gmail.com.
Dec 30, 2009 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
How do I go about installing XP when the previous operating system was deleted. Got XP operating system disc, but doesn't load.
Write zeros to the hard drive using the software from the hard drive manufacturer. Then you will be able to format it and install your XP
Oct 21, 2009 | Microsoft Windows XP Professional With...
When I created the partitions, all seemed o.k, but when I installed Windows, the PC get crazy. When I eliminate the partition and again I create it with partition magic,it reports all o.k. But when I...
I never did like norton stuff.
format the whole hard drive as one partition (not with norton)
use FDISK or similar
then to let the xp disk do its own thing
after xp is installed and running fine then run norton PM and resize to what you want for the C drive and let norton do its stuff.
you should now have C and D drives. if you want to split further use norton PM again and resize D and once again let norton do the business. you should now have C, D(but smaller) here I would use microsofts disk manager or norton toformat the last bit if thats what you did. and so on ad infinitum.
the 110 error means there is alread xp on the destination and it cannot go ahead usually if i was doing a clean install i would not have told it to leave the system intact but told it to go ahead and format (unless i was doing a repair install)
Aug 14, 2009 | Symantec Norton Partition Magic-8.0...
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Nokia phone wont connect to the GPRS
Creating Data Accounts
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
May 06, 2009 | Nokia 5310 Cellular Phone
Formatted a WD500GB hard drive with windows xp using the fat32 format. the disk space shows only 1.99GB FREE HOW CAN I GET THE DISK TO BE THE FULL CAPACITY MINUS THE OPERATING SYSTEM, ...
Creating and formatting a new partition:
  1. In the lower windowpane on the right hand side, you should see unallocated space for the drive. Right-click anywhere on the unallocated space to see a menu of available options.
  2. Click on Create Partition
  3. The Create Partition Wizard will appear. Click on Next.
  4. Leave Primary partition selected and click Next.
  5. Choose the partition size and click Next.
  6. Leave Assign a drive letter. selected and click Next.
  7. Leave Format this partition with the following settings: selected and choose the file system you want. Select Perform a quick format and click Next.
  8. Click Finish.
  9. Under the drive it will indicate that the drive is formatting and will show you a percentage complete. Depending on the size of your hard drive and the speed of your computer, it could take more than an hour to format the whole drive.
Oct 19, 2008 | Computers & Internet
Won't start
Boot using Recovery CD and run chkdsk /R C: to fix errors then reboot.
You may have to install a 2nd copy of XP which will trash the first copy but at least leave your data files intact.
Aug 07, 2008 | Dell Latitude D600 Notebook
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
110 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
