Question about InFocus Proxima UltraLight LX2 Multimedia Projector
My Proxima Lx2 has a bulb issue
I just put a new bulb in my Lx2 but the lamp light will not go off and after olny a few minutes the unit will shut off. Can you tell me if I have the right bulb.I have a ump150w #100880176 thank you for your time
  • 563 Answers
Hi there
You have to reset the lamp timer.
Should solve your problems.
Posted on Apr 02, 2008
Why is our Proxima Desktop Projector 8000 turning off after a period of time?
There is a THERMAL fuse that is used to prevent fires and electrical destruction of the unit. Lamps get very hot and unless the AIR flow is good, the temperature gets too hot and shuts down the system. The fan speed may be too low, the unit may need to be cooled down with an exterior fan? Try options.
Jan 04, 2015 | Office Equipment & Supplies
Proxima dp6150 shuts down unexpectedly
the interface between the mother-board and the power-supply is not work well
Add some solder on the interface , it will increase the contact surface
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, motherboard,
powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 18, 2014 | InFocus Proxima DP6150 Multimedia...
I have power to my Proxima ultralight LX2, the ready button is green and the lamp is red. The machine will power on for a short time and then power off with a flicker of light from the bulb. I am...
It sounds like you should check the lamp to see if it has too many hours on it. The bulb should look pretty clear & round without bulging & dark spots or fogging. If it has a lot of hours it needs to be replaced. It may also be a fan that is not turning on or is not turning fast enough. Use canned air & while unplugged spray the fans to make them spin fast. You can use a flashlight to try & locate the fans behind the vented areas arount the case. If a fan is not working properly it will cause the unit to shut down. Also check your indicator lights on top & compare with the troubleshooting portion of the user guide. You can get a user guide download from google search.
Good luck,
Jim
Apr 14, 2011 | InFocus Proxima UltraLight LX2 Multimedia...
Hi i am wondering how i can clean or even get into my proxima ultralight lx2 , its 10 years old now and the inner two or three lenses need cleaning as the picture is showing up some dust , i was thinking...
The lens should be pretty sealed up. Use some compressed air, and a lens cleaner on the front of the unit, and see how that goes. If it needs further service of the lens you may need to bring it to a professional.
Feb 28, 2011 | InFocus Proxima UltraLight LX2 Multimedia...
My projector keeps shutting down(sleep mode) after only being on for 5 minutes. how can I stop that from happening?
The problem with you Projector is most likely the bulb. Here is a good guide on how to change out the lamp on your projector:
http://www.fixyourdlp.com/guides/ask-proxima/sp-lamp-017/ask-proxima-sp-lamp-017-lamp-replacement-guide.php
I also suggest reading about the counterfeit lamps and buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Mar 04, 2010 | ASK Proxima C160 Multimedia Projector
Proxima c420
yes. the lamp is starting to go.
Aug 19, 2008 | ASK Proxima C420 Multimedia Projector
Ask proxima m2+
lamp gets brighter & brighte within a minute & immidiately color wheel stops rotating & projector goes to standby mode. for 3 to 4 minutes again same symptom contimuously observed pls guide me which part is suspected
Jan 16, 2008 | InFocus ASK Proxima M2+ Multimedia...
Proxima Ultralight x350 no valid input source error?
reset the settings to factory default. if that doesn't work, the lamp may not have enough power to stay on. if the lamp doesn't have many hours on it, it's the ballast.
Jan 05, 2008 | InFocus Proxima UltraLight SP1 Multimedia...
Proima lx2, darkening of the image and slight shake
either the fly-eye lens or the light polarizer is fried due to excessive dust and heat. bad news: you'll have to replace the entire optical engine. worse news: infocus doesn't make them anymore. sorry.
Sep 02, 2007 | InFocus Proxima UltraLight LX2 Multimedia...
InFocus Proxima UltraLight LX2 Multimedia Projector Logo
243 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
