Question about Plumbing
I have a trench 1475' long, with three rows of 3'' pipe.
I have a trench 1475' long with three rows of three pipes (nine total) each pipe is 3'' diameter. What is the total cubic yard of displacement o*** the pipes? (the trench is 36'' deep x 37'' wide and filled with concrete. I need to know how much concrete is displaced by the pipe.) I came up with 505.32 yds of concrete before displacement
    Problem Solver:
  • 19 Answers
24.14 cubic yards
Posted on May 18, 2010
What are the 12 days of christamas in order
12) 12 Drummers Drumming
11) Eleven Pipers Piping
10) Ten Lords a Leaping
9) Nine Ladies Dancing
8) Eight Maids a Milking
7) Seven Swans a Swimming
6) Six Geese a Laying
5) Five Golden Rings
4) Four Calling Birds
3) Three French Hens
2) Two Turtle Doves
1) A partridge in a Pear Tree
Dec 01, 2015 | HP Computers & Internet
Where do the three petrol pipes connect
http://www.mcculloch.com/ddoc/MCCI/MCCI2002_AAaa/MCCI2002_AAaa_Virginia-MH542_.pdf
Oct 01, 2014 | Garden
Septic tank drain field
dig trench
lay gravel
lay perforated pipe
lay red paper over pipe
add more gravel
cover with dirt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 13, 2014 | Water Heaters
Hello......can anybody give any solution for this problem : my VGA Cable disconnect from the 15 Pin gents connector of Crt monitor of philips model no. 107E61 I want to fix it but I could not understand...
These connectors come with 15 pins and 9 pins. But be carefull, the nine pin connecter uses a tottaly different color code. Thats for an oldschool gamepoort or midi connector. But I think the vga connector has 3 rows of pins total of 15. But the nine pin connector has probably two rowes of pins. And thats no vga connector, but an connector for an serial port.
If it has three rowes (see Fig-2 below) but uses 9 pins then its an RGB instead of VGA.
Fig-1
Fig-2
Fig-3
Mar 19, 2017 | Cars & Trucks
How to connect a vanity 2 inch drain pipe to a three inch toilet drain pipe
You can by 3">2" rubber adapters from most plumbers merchants for a few quid
Jul 07, 2012 | Furniture
The 3/4" main water line has a leak and needs to
Hi. I seriously doubt that you can avoid digging a new trench.
Aug 01, 2011 | Plumbing
What size npt thread is the adaptor
Common American National Standard Pipe Taper Threads
  • NPT - National Pipe Thread Taper
  • FPT - female (internal) National Pipe Taper threads
  • MPT - male (external) National Pipe Taper threads
  • NPTF - Dryseal American National Standard Taper Pipe Thread (ANSI B1.20.3)
For NPT threads a sealant compound or Teflon tape must be used for a leak-free seal. For NPTF no sealant is needed for a sealing.
Characteristics of NPT (also known as ANSI/ASME B1.20.1 Pipe Threads, General Purpose):
  • tapered thread 1o 47'
  • truncation of roots and crests are flat
  • 60o thread angle
  • pitch is measured in threads per inch
Note! Pipe sizes do not refer to any physical dimensions. The outside diameter of a pipe or fitting must be measured and compared to a table for size identification. A 3/4" NPT pipe thread has an outside diameter - OD - of 1.050 inches.
Each thread size has a defined number of threads per inch - TPI, or pitch. The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because more than one size have the same TPI.
NPT - American Standard Pipe Thread Taper 1) Pipe Size
(inches) Threads per Inch
TPI - pitch Approximate Length of Thread (inches) Approximate Number of Threads to be Cut Approximate Total thread Makeup, Hand and Wrench (inches) Nominal Outside Pipe Diameter
OD
(inches) Tap Drill
(inches) 1/16" 27 0.313 1/8" 27 3/8 10 1/4 0.405 R 1/4" 18 5/8 11 3/8 0.540 7/16 3/8" 18 5/8 11 3/8 0.675 37/64 1/2" 14 3/4 10 7/16 0.840 23/32 3/4" 14 3/4 10 1/2 1.050 59/64 1" 11-1/2 7/8 10 9/16 1.315 1-5/32 1-1/4" 11-1/2 1 11 9/16 1.660 1-1/2 1-1/2" 11-1/2 1 11 9/16 1.900 1-47/64 2" 11-1/2 1 11 5/8 2.375 2-7/32 2-1/2" 8 1 1/2 12 7/8 2.875 2-5/8 3" 8 1 1/2 12 1 3.500 3-1/4 3-1/2" 8 1 5/8 13 1 1/16 4.000 3-3/4 4" 8 1 5/8 13 1 1/16 4.500 4-1/4 4 1/2" 8 5.000 4-3/4 5" 8 1 3/4 14 1 3/16 5.563 5-9/32 6" 8 1 3/4 14 1 3/16 6.625 6-11/32 8" 8 1 7/8 15 1 5/16 8.625 10" 8 2 16 1 1/2 10.750 12" 8 2 1/8 17 1 5/8 12.750 14" 8 14.000 16" 8 16.000 1) The taper is 1/16 inch in an inch, which is the same as 3/4 inch in a foot (angle 1o 47')
NPT threads are not interchangeable with NPS - National Pipe Straight - threads.
NPT threads may look similar to ISO 7/1 threads. However, ISO and NPT threads should not be mixed. ISO threads have 55o taper angle versus 60o for NPT. The NPT root and crest configurations are also different from ISO. For ISO threads pitch is usually measured in millimeters (may be expressed in Inch). The pitch are different.
Feb 28, 2011 | RTO 1 1/4" Drop Pipe Bronze Pitless...
Where do we find the o2 sensor to replace it on 1996 ford explorer v-6 4.0
Item Part Number Description 1 52 Exhaust Inlet Pipe 2 N803420-S2 Exhaust Manifold-to-Inlet Pipe Bolts
(4 Req'd) 3 5E212 Three Way Catalytic Converter 4 5230 Muffler 5 N620482-S2 Exhaust Inlet Pipe-to-Converter Nut
(3 Req'd) 6 5B266 Exhaust Converter Inlet Pipe Gasket 7 N620481-S2 Nut 8 5E269 Exhaust Converter Frame Bracket 9 N620481-S2 Nut 10 5260 Exhaust Outlet Pipe Frame Bracket 11 5E269 Exhaust Converter Frame Bracket 12 39006 Screw and Washer 13 5E241 Exhaust Converter Outlet Gasket 14 5G215 Exhaust Pipe Flange Hold Down Spring 15 N802641-S2 Nut and Retainer 16 — Rear Heated Oxygen Sensor (HO2S) A — Tighten to 34-46 Nm
(25-34 Lb-Ft) B — Tighten to 20-25 Nm
(15-19 Lb-Ft) C — Tighten to 34-46 Nm
(25-34 Lb-Ft)
Apr 03, 2010 | 1996 Ford Explorer
If the pipes are 3" outside diameter, the displacement is 24.15 cubic yards, however standard 3" pipe is 3.5" diameter, which would displace 32.85 cubic yards. 505.32 cubic yards is correct for the total trench volume.
Mar 23, 2010 | Plumbing
Level 3 -a or one
Coin 1: After the checkpoint, there are pipes blowing bubbles upwards. The
second set of pipes is a red followed by two greens; enter the first
green pipe (the middle pipe of the set) and swim across the cavern to
get the coin.
Coin 2: About two thirds of the way through the level, the coin can be seen at
the top, between two bubble-blowing pipes. Swim up and get it, but
beware the purple fish that will swim after you.
Coin 3: About three quarters of the way through the level, there is a P switch.
Hit the switch and immediately swim right; the coin is easily grabbable
at this point.
Apr 11, 2009 | Nintendo New Super Mario Bros. for DS
Plumbing Logo
74 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
