Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Craftsman Sprocket replacement procedure
Help. My 1997 vintage 1/2 HP Sears Craftsman Garage Opener needs a sprocket assembly change. I have removed the outer casing and can see the shreds of the plastic sprocket and know i need to replace it. However i am little more challenged in not knowing how to remove and then install the sprocket. Any help would be appreciated.
  • Anonymous Apr 02, 2008
    I replaced my gear sprocket assembly over the weekend and everything went pretty good. The problem is that when I push the button on the garage door the door only move about 2 feet in either direction. I adjusted the distance up and down but nothing. I looked at the gear that controls the distance and it seems as if the garage door is stopping before the sensor inside the opener is touched. Any ideas???
  • Anonymous Apr 03, 2008
    Need a garage door screw, which is worn down. The screw which turns the sproket to drive the chain and door. Where do I get parts for it??
  • 5 Answers
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Posted on Jul 10, 2008
You need a gear kit. Amazon sells them. I got mine at a Sears Service center. Beware that you will need to completely disassemble your unit to replace the gears.
http://www.amazon.com/Sears-Craftsman-Liftmaster-Garage-Opener/dp/B000JGLX9C
Posted on Apr 02, 2008
SOURCE:
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Replace the gear and sprocket assembly on a garage door opener
I had to retension my spring assembly on the garage door a few years ago and I don't recommend anyone without proper tools and some experience to do it. It can be dangerous.
Nov 14, 2013 | Craftsman 1/2 HP CHain Drive Garage Door...
Sears Garage door opener #41A3625, chain sprocket hanging on the bar. I went to open the door this morning it was frozen and it didnt open. i went out to see why and i saw the chain hanginging, and the...
It sounds like the shaft for the sprocket and drive gear has broken or been sheared off. The part number for this assembly is 41C4220A and is available from Sears parts or any good local door opener company. It comes with instructions if you want to do it yourself.
Jan 03, 2012 | Sears Craftsman LiftMaster Chamberlain...
The chain came off my Craftsman 53920 garage door opener. How can I fix this problem?
When a chain comes off it is an indication of another problem. The bearing on the sprocket shaft is bad and lets the sprocket lean forward and the chain pops off. The part number you need is 41C4220A Gear and Sprocket Assembly. The chain can be loosened by the nuts on the trolley.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener is malfunctioning
It sounds like the gear and sprocket assembly has gone bad. This would cause the symptoms you have.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Model# 13953919 not working.
Yes replace the entire assembly. The part number is 41C4220A Sprocket and Gear Assembly and is available at Sears or any good door opener service company. It comes with instructions.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
The chain has come off the sprocket.
The gear/sprocket assembly needs to be replaced with part # 41C4220A. The top bushing is worn out that is why the chain fell off.
Dec 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
906 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
