Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Maytag MDB6100AWB control panel lights "stuck"
The dishwasher buttons are lighted stuck. The buttons are the delay at 4 hours heavy wash and heated dry. Anyone help?
SOURCE: maytag mdb7130aws dish washer
yes i have power to water valve.
Posted on Jan 08, 2008
  • 1003 Answers
SOURCE: Maytag MDBH950AWS Dishwasher won't start
REPLACE TIMER
Posted on Jan 18, 2008
SOURCE: "Dry Light" Lit up, won't start. Maytag Jetdry Dishwasher DWU9906
99002254.jpg View Larger Image
Posted on Jun 02, 2008
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Posted on Dec 28, 2008
  • 10865 Answers
SOURCE: Maytag MDB6100AWB is leaking around the heating element
There is a gasket on the heating element. You could turn off the power and tighten the heating element or replace the gasket. good luck cathy.
Posted on Jan 27, 2009
How do I reset the code.the lights are lit 4 hour delay, rinse only steam clean.
THIS DISHWASHER WAS RECALLED BY MAYTAG.. You might want to call them to see if it is still covered.
If already repaired you might try:
Normal - heated dry - normal - heated dry. then try to use the machine.
Oct 19, 2015 | Maytag MDB7809AWB - MaytagR JetcleanR Plus...
Frigidaire FFBD2406NW0A then clean wash drying and 4 hour led lights are blinking
I appreciate your post, friend!
I understand that the clean, wash, and dry buttons on your Frigidaire dishwasher are blinking along with the four LED light. This appears to be a delay start cycle. I would recommend pressing the cancel button. If that does not clear the lights you can perform a reset and to do that you would need to disconnect power from the dishwasher for roughly ten minutes. I hope this is helpful. -Matt
Feb 20, 2015 | Frigidaire Dishwashers
My maytag dishwasher dosnt work. the delay light 2,4,6 lights just blinks. I would like to know the reset code to see if i can do a cycle run.
I pressed heavy wash 3 times and then start to make it perform a field test. It tested fine, but it stuck at 61 minutes for an hour while I was testing auto clean. Another thread indicated that the controller cable interface was getting moist.
Dec 05, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Maytag dishwasher MDB6100AWB
None of lights or bottom do anything on the front panel of the model mdb6100awb.
Anybody got a answer for this.
May 27, 2012 | Maytag 24 in. MDB6600A Jetclean II...
Whirlpool dishwasher model# DU915PWSS0 S/N# DE3960705 reset procedure? The problem: dishwasher will not start the only buttons that will light up when I push them are heavy, rinse only, and heated dry. I...
  • Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
  • 3
    Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
  • 4
    Repeat step 3. This will reset the dishwasher.
  • May 11, 2011 | Whirlpool Dishwashers
    Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
    Door latch.
    Open and close the door to make sure the door latch is securely fastened
    Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
    Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
    Oct 06, 2010 | Dishwashers
    Maytag 24 in. MDB6100A Built-in Dishwasher Logo
    70 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
