Question about LG WM-1832C Front Load Washer
Only spins 1 way - LG WM-1832C Front Load Washer
  • LG Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machineonly spins 1 way - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Washer wont spin code e57
High current issue - 1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free? No, replace the motor. Yes, go to step (3). 2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3). 3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Aug 19, 2012 | Frigidaire Affinity ATF7000E Front Load...
Spinner on twin tub washing machine not spinning
I have had a manatee twin tub washing machine with spinner for two years. When I went to spin dry the first load this evening, it would turn on, but not spin. I read the above entry about another twin tub. I did the following... I unplugged the machine for 1 minute. Plugged it back in, then slowly and carefully turned the spin tub clockwise for 1/4 turn, then counter-clockwise for 1/4 turn. I cannot explain why it worked, but it did. So, try this trick before taking it apart. Good luck!
Jan 15, 2012 | Washing Machines
Tray 1 will not feed
Look at the tray 1 feed roller with paper in the tray.
Make sure that it is spinning.
If it is spinning, clean it with a damp lint free cloth.
Pull out tray 2 while you try to print from tray 1. Again make sure that the roller is spinning.
If it isn't spinning you have a problem that could be major.
Jan 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Machine fills, adgitates, but doesn't drain and spin.
that means your motor is not reversing to drain or spin , your motor turns 1 way to agitate and the other way to drain and spin ,motor could be out on 1 side
Feb 20, 2010 | Kenmore Washing Machines
Will spin but not agitate LWA40Aw2
Hi, it sound likes a belt. Some amana washers take 2 belts,1 for the spin,and 1 for the agitate. or some models spin rite of motor,and a belt for agitate. hope this helps. :)
Jul 07, 2009 | Amana ALW895 Top Load Washer
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
LG WM-1832C Front Load Washer Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
