Question about Epson P-5000 Digital Media Player
Epson P5000 won't switch one
I dropped my Epson P5000. Picked it up switched it on and thankfully it worked fine. Used it a number of days and it worked fine. One day it froze up and I had to remove battery to sort it out. Ran fine for another two times. Then it switched on and will do nothing showing the lock symbol on screen even though not in the lock position. Now it will only switch on if connected to the power supply and still shows the lock symbol and a flat battery symbol. Does not seem to charge. Please help before I take it in. It is out of warranty.
    Sergeant:
  • 154 Answers
You have possibly damaged or disturbed internal connections which only an engineer can fix due to fiddly parts and a dust free environment, It hinges on the cost of repair?
Check on ebay etc to find its current value and use that as a guide to compare with a repair quote, if its not worth it put it up for auction to recoup some cash against a new one.
All you can do is check any removable parts battery, card etc are secure, their internals are frail to damage. Check for home contents policy against accidental damage?
Sorry, hope this helps...................
Posted on May 09, 2017
2 Suggested Answers
  • 9 Answers
SOURCE: Epson P5000 won't switch one
its software have been frozen or crupted connect it to pc and upload a software
Posted on Mar 23, 2010
Could you provide me the Windows 7 64bits for P5210?
There is not a windows 7 driver for the P5000, but the P7000 driver has been fully tested by Printronix to work with the P5000. Alternatively you can use the printer in Epson emulation mode and use the Epson 1080 driver included in Windows7.
Jun 12, 2014 | Printronix Line Matrix P5210 Printer
Vacuum was working fine one day, next day it won't come on
You can try doing this first, plug it in to your outlet and switch it on. If it will not start, try to move the wire near the plug to see if the problem is a lose wire in that area. If it responds in moving the wire you have to replace the plug of your vacuum. Message me if you need further assistance. Thanks..
Jul 22, 2012 | Vacuums
My Lumix DMC-LX5 camera won't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
My Bosch 18V planer 53518 just stopped working. Worked fine one day, picked it up the next day, nothing!! Batteries fine, checked belts, etc. I see no problem. Any suggestions?
Did you ever figure this out? Mine just did the same thing. Fresh battery. Pulled trigger. Started to run, then just stopped. Don't know if it's the switch, motor or something else.
Oct 28, 2011 | Bosch 18V Cordless Planer 53518
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
My 1996 Lincoln Town Car will not start, as if a kill switch was set. the car runs fine for days and for no reason it won't start, I though it was the anti theft circuit, but have not been able to...
Your best bet , take it an have some testing done . Fuel system , engine management system , electrical system test etc.... Could be any number of thing's ,guessing an just replacing parts doesn't work . Won't start how ? When you turn the key to start does the starter spin the engine ? Crank - no - start ! Or you turn the key an nothing happens ? No crank no start .
Testing Electric Fuel Pump Problems with Voltage Drop Test
048 Engine Hard to Start or No Start Scan Data for Starting Problems
Sep 07, 2017 | 1996 Lincoln Town Car
After switching on my Epson CX6400 it shows immediately after recalibration the error message ' Printer Error - please consult service' (in German: 'Druckerfehler - Bitte wenden Sie sich gegebenenfalls an...
have you tried OEM ink on this printer? becaus my mother did that and it ruined the printer head all it did was drop ink all over your paper and make the printer stop and clean the head
Mar 06, 2011 | Epson Stylus CX6400 All-In-One InkJet...
Mar 23, 2010 | Epson P-5000 Digital Media Player
A70 will no longer switch to the "view picture" mode anymore. Camera was dropped
Here's a disassembly guide for your camera. It's in Estonian, but has lots of pictures to show you the steps to get in there. If you do get it open, try not to touch any of the elctrical connections or you might get a small shock from the flash capacitor.
http://qman.fotokala.ee/Kaamerad/PowerShotA70/index.html
Nov 17, 2006 | Canon PowerShot A70 Digital Camera
Epson P-5000 Digital Media Player Logo
43 people viewed this question
Top Epson Audio Players & Recorders Experts
Tom Chichester
David Tickner
Bill Boyd
Are you an Epson Audio Player and Recorder Expert? Answer questions, earn points and help others
