Question about Nokia 6300 Cellular Phone
My phone sanks in water and the backlight of my phones lost
Try sticking your phone overnight in a bowl of uncooked rice. Sounds insane, I know, but I've seen it used to fix waterlogged phones a billion times. It's easy to do and worth a shot. Best of luck!
Posted on Aug 02, 2010
I recently sank my 1998 Honda 250 recon. I have changed the oil and cleaned the carb but it is blowing lots of white smoke.
if it was running when you sank it, it more than likely sucked water into the cylinder and you have some broken piston rings.
Jun 18, 2013 | Motorcycles
Fell my xperia s in salt water
This happened to my phone once, I just took it apart (the bits I could, sim card, battery, cover etc) then dried it for quite some time with a hairdrier (on a cool setting) then left it over night apart. Put it back together in the morning and it worked. I'm guessing there was still water/ moisture inside of it to stop it working..
Mar 04, 2013 | Sony Ericsson Sony Xperia S Lt 26i 32gb...
How I turn off swype tutorial on lg optimus?
with my LG phone the solution to it was take it out to the lake and use it for a skipping stone. It didn't even work well as a rock except for the part where it sank.
Apr 14, 2012 | LG Cell Phones
I sank my 91 toyota 4runner and have a knocking in the engine.
If by "sank" you mean submerged in water while the engine was running you probably bent a conecting rod or broke a piston. Water does not compress and if the engine ingested water you have done some major internal damage. No quick fix for this, the engine has to be rebuilt.
Jan 18, 2011 | Toyota 4Runner Cars & Trucks
oh dear no you already late for servicing your cell phone mother board. so you fell this problem. what ever now i think your display LED has damaged. or may be i has short circuit. so as soon as possible go to any professional technician. thanks
Mar 23, 2010 | Nokia 6300 Cellular Phone
I want to replace the LCD backlight on my ZTE F156
you need replace LED on nokia 6070 backlight . or more easy you replace the LCD, backlight on LG not same with Backligt of nokia
Nov 07, 2009 | Nokia 6070 Cellular Phone
My Nokia 3220 is continuously buzzing when I inserted the battery. Set was sank in a bathtub and soaked.
remove the battery and flip the phone upside down to air dry. Check where the battery goes to see if it was water damanged by the white dot being pink.
Sep 26, 2009 | Nokia 3220
Network ICU is damaged due to water in NOKIA 3110c
I'm not sure what your question is..
However if it fell in water the ONLY thing you can do is IMMEDIATELY take the battery out and let it and the phone dry COMPLETELY.
Even that is not guaranteed to work, if you've done so or failed to do so and it is not working or working improperly the phone is useless. There is little anyone can do except replace it.
Sorry about your luck, if you had another question please post.
Mar 17, 2009 | Nokia Cell Phones
Solutions for nokia 2310 backlight
good day,
i suggest that you don't turn on the phone if it is not yet thoroughly dried, this might cause some short circuit on the system. you can use a hair drying in doing this.
however, if you're certain that your phone is already dry, try turning it on and check for errors. in the case that you stated, it seems that your phone has been damaged due to being submerged in water. if the backlight will not turn on again after making sure that your phone is thoroughly dried, have it checked by a competent technician and prevent further damage to your phone.
i hope this will help
Oct 13, 2008 | Nokia 2310 Cellular Phone
BACKLIGHT STILL ON
How wet did it get? Was it submerged? The backlight would normally shut off after a short idle period or when you close the cover. If it is staying on all the time after water damage then there is still water in a component (like a capacitor) or corrosion that has opened or shorted a circuit path somewhere confusing the phone. There is a good chance that corrosion will become worse and do more damage. New problems could arise any time in the next few days or few years. If this were my phone I would disassemble it and clean it with rubbing alcohol, toothbrush, and air duster but there is some risk even for someone experienced. Also, microphones can be damaged by fluids including rubbing alcohol.
Jul 08, 2007 | Pantech C300 Cellular Phone
Nokia 6300 Cellular Phone Logo
67 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
