Question about Speedo Aquabeat LZR Racer 2GB Waterproof MP3 Player MP3 Player
My aquabeat 2gb doesn't eject properly from my mac. It seems to eject and then reconnect instantly. When I unplug it it says it was not disconnected properly. I did not think this would be a problem but last time it did not work and the led just flashed orange and the music did not play. My mac still recognises it as a drive. Any suggestions? Thank you.
Hello, I have the same problem with mine. Did you finally find a solution for yours?
Best Regards, Sylvie
Posted on Aug 10, 2010
CD stuck
Restart the computer, and press and hold the "C" key as soon as you hear the startup chime. The CD is most likely not a system disk, so if the CD mechanism is functioning properly, it will be ejected. Note: this works on older Macs. In newer systems, it may be ignored.
If this doesn't work, get a medium to large - size paper clip, and straighten out one bend. At the left end of the slot, there is an emergency eject actuator about 1/4"-1/2" inside the CD drive. Push the end of the paper clip wire straight in at this point. You will feel some resistance at first, then the eject mechanism should start to move and the disk will appear.
Unless there is some odd problem with the disk (e. g. an adhesive label coming loose and hanging up in the drive, I'd be suspicious that the optical drive has a problem and should be replaced.
Feb 02, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have just brought a imac computer, how do I get the program required to use my speedo aqua beat
website says the software is not compatible with mac, but it states that when you connect the device to your mac a folder should show up on the desktop and you can just drag songs into that folder
http://help.speedo.com/app/answers/detail/a_id/75/~/how-do-i-use-the-speedo-aquabeat-playlist-editor-software%3F
Aug 12, 2011 | Speedo Aquabeat MP3 Player i
Speedo MP3 pink 1 gig. When I plug into my Mac (yes, Mac hooked to power source; yes, plugged directly into the Mac's USB) I continually get a message saying I've ejected incorrectly. Then shortly...
It probably means your usb connection is loose. You can try another usb port on your mac, if that is better then the usb port you usually use is bent or has a loose connection, if not the problem is likely the MP3 player's usb.
You could try putting a small amount of weight on the MP3 Player while its plugged in to improve connection. While it is plugged in, use your finger to lightly move the device up or down and hold gently. If the connection improves, use a small weight to hold device in that spot. If you are pushing down put a small box on top of the device, if you are pushing up, gently wedge something underneath drive.
Hope this helps.
Sep 20, 2017 | Speedo Aquabeat (2 GB) MP3 Player
How do I eject a DVD from my macbook? It's seems to be really stuck.
Here are the usual methods of ejecting from a mac... http://guides.macrumors.com/Force_Eject_a_Stuck_CD_or_DVD
If that doesn't work, try my guide here...http://www.fixya.com/support/r5390314-eject_disk_from_slot_drive_when_ve
Sep 18, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Speedo aquabeat 3g mp3 player is not charging. The LED light turns to green, but when I unplug it it won't work.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
Feb 19, 2010 | Speedo Aquabeat MP3 Player i
Speedo Aquabeat is not recognized by my Macbook Pro
I plugged my aquabeat into my mac. It mounted and I deleted all the files onto it. Then, I copied a bunch of mp3 files onto it. The device registered as full and wouldn't let me add any more files even though the info window said there was 250 MB available but this was wrong or misinterpreted by the device. I couldn't make it work. I found there was insufficient capacity for the operational files to be built on the device. I deleted one of the mp3 files to free up space then ejected it which caused it to be unmountable on the mac - it wouldn't turn on at all. I pressed the reset button and it all came to life and now it works as advertised. The device needs to create a bunch of work files for it to start. I believe that it really was out of space and could not create the work files. When I deleted the mp3 it freed up enough space so the work files could be created, but it was frozen. The reset caused the work files to be created and all was well.
Aug 22, 2009 | Speedo 7410061 MP3 Player
I DO NOT HAVE A PROMPT ON MY COMPUTER TO CLOSE MY SANDISK. I DON'T WANT TO DAMAGE IT.
What kind of computer are you using? PC or Mac? If you're using a PC, you can just unplug it when you're done. If you're using a Mac, you drag the icon to the trash can icon to properly eject it.
Jul 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
Apr 24, 2009 | LaCie Computers & Internet
Sony NWZ B135F Walkman won't disconnect
  • In mac open Disk Utility
  • Select the volume named WALKMAN
  • Hit UNMOUNT
  • Disconnect the player
The trouble is that the player doesn't respond to the comand EJECT in this process a loop started unmounting and seconds later mounting the volume again.
Hope this helps
Jan 06, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
LG KG-800 with Mac OS X (eject issues)
First scan your mobile with anti virus and then format your mobile next connect and add files and close all the programs running and refresh your system and then click eject or in taskbar click on safely remove hardware and disconnect it.
Aug 10, 2007 | LG KG800 Cellular Phone
Speedo Aquabeat LZR Racer 2GB Waterproof MP3 Player MP3 Player Logo
261 people viewed this question
Top Speedo Audio Players & Recorders Experts
aliasger yq
Amelia starnes
Amelia starnes
Level 1 Expert
John Craig
John Craig
Level 1 Expert
Are you a Speedo Audio Player and Recorder Expert? Answer questions, earn points and help others
