Question about Protron PLTV3250 32 in. LCD Television
No video/ does not power on
Ithe screen stoped showing picture but for awhile it use to have adiuo and now it no longer even powers up
  • 11,361 Answers
Check the power supply, you must have at least the +5vdc standby voltage at the power output connector, look for bad caps withleaking/bulging top, you may also have shotrted out Q7 and ZD4 in the +5vdc standby power supply section. Hopefully you do not have failed inverter bd. too. The power supply module and the inverter board are common parts that failed.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Posted on May 31, 2010
Hdmi 6 and 7 do not work
HDMI does not like connections made with units powered and or on.
Try removing power from the units connected and the set for a while, reconnect them and then connect power to see what happens.
Most Sony sets have a reset but try the suggestion above first.
Dec 03, 2012 | Sony Grand Wega 50 in. Diagonal Class Full...
Samsung 793S (Black) 17
On these older CRT monitors when you have that type of problem it indicated that the high voltage power supply is not putting out the right voltage to charge the picture tube. As the power supply gets weaker the time to show a picture will take longer and longer. It is not worth repairing the unit because parts will run much more than a replacement monitor.
Jul 19, 2012 | Samsung 793S 17" CRT Monitor
Acer Aspire 4930 not starting.... only black screen
Hook a spare monitor to the video output, usually on the back, if picture okay! the LCD screen on the laptop has a bad inverter board or the backlight behind the screen has failed. But if both show the same symptom the Video Graphics Card is bad usually built into the motherboard.
Mar 21, 2012 | Acer Aspire 4930-6862 Laptop
I have a TLA 04641C serial # BR8B0505560002883 Polaroid TV
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 02, 2017 | Polaroid FLM-3201 Television
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
Drained batteries
Digital cameras do use a lot of power to operate. Somethings can make the batteries die faster. Even if the batteries may have worked in other cameras after ou used them in yours could just be that the other camera requires less power to operate then yours. Turning off and on the camera or simple viewing them can use more power then usual. Try and avoid this to see if it last longer. Also, try and see if there is an auto shut of to save power when you leave the camera on. If you have an eye piece use that to take pictures instead of the display this will also save on power consumption. Also, when you know that you won't be using the camera for awhile meaning you are storing it then remove the batteries. Some electrical items even if the camera is off they can still be draining the batteries.
If these don't help then I would have it looked at especially if you are under warranty.
Jun 09, 2008 | Olympus SP-550 UZ Digital Camera
No screen
Does the power light come on? If not it could be a power supply or adapter. If you have a power light, hook up the PC to an external monitor(if available) and if that works, it would be either your screen or video adapter.
Dec 06, 2007 | Acer Aspire 3000 Notebook
Protron PLTV3250 32 in. LCD Television Logo
64 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
