Question about Amana AMV6177 Convection/Microwave Oven
Can't find a user manual for my Carlton C25MW09 Microwave. Although a current model doesn't seem to be a manual I can download. Any suggestions? Supplier can't help - last one in the shop and they've lost the handbook - still it's the only 900watt at the price and I thought sure I'd be able to find help on the web. Anyone?
Manual for Carlton C179SS09
Go to manufacturer web site for download.
Sep 19, 2015 | Carlton Microwave Ovens
Instruction manual for carlton microwave C21CS09
Currys PC WorldHi Simon,
Thank you for getting in touch.
It's great to hear that you're satisfied with your microwave! My apologies - after searching (and believe me I searched everywhere) I have been unable to locate a manual for the Carlton C21CS09.
You have my apologies for the inconvenience caused.
Kind regards,
Matt
Apr 01, 2012 | Carlton Microwave Ovens
I need a user manual for Panasonic Microwave NNA880W
Thanks everyone for the links to the various download sites. However none of them seem to have the specific manual for the Panasonic NN-A880W mirowave.
Is this an obscure model?
I have just been given this model and cannot seem to find a users manual anywhere on the internet.
If anyone knows where to download one from, I would be eternally grateful.
Many thanks
Kevin
Feb 17, 2012 | Microwave Ovens
Carlton Microwave - C25MW09. Microwave unit stays on after timer has finished although light goes off and turntable stops rotating. Have to turn it on and off at the mains otherwise microwave unit would...
It is possible that the relay is staying latched to supply voltage to the magnetron even after the timer shuts down. This is dangerous and must be rectified.
You need to check the door switch and the lines from the program timer to switch the relay of the magnetron. It is possible that the timer is faulty and needs a check on the reason why it stays latched unless the power is cut. You can disconnect the magnetron to test but attempt ONLY if you are familiar with high voltage/ electrical circuits.
Jul 09, 2011 | Microwave Ovens
I have a second hand Carlton microwave model no C25MW09 without an instruction manual. Can you help?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies and as required.
The information is normally free of charge.
Mar 01, 2011 | Microwave Ovens
Need a manual for a Carlton Microwave / Oven / Grill combination, model number C21CS09
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
I hope this helps.
Jan 13, 2011 | Microwave Ovens
There seems to be no power. No clock. no nothing. It was working fine and then jut stopped. Circuit is not tripped. I tried unplugging and plugging again.
most likely you will have to remove the louvers or trim above the cooking cavity to get to the fuse, look for screws holding the trim/louvers on, if no screws are apparent, the piece may slide to the left or right and pop off.
Unplug your microwave. Although it might seem like no electrical current could possibly be running through your appliance, it could still have stored electrical current somewhere in the system. Be safe rather than sorry and unplug it before you begin.
  • 2
    Find the wiring diagram for your model of GE microwave. You can contact GE directly to get this if you cannot locate your owner's manual. Note the fuse locations and get a screwdriver. Some GE fuses are located under the louvers, while others are located in the door.
  • 3
    Open up the microwave and locate the blown fuse. Sometimes you cannot determine a blown fuse by visual inspection so check it with a multimeter for continuity across the terminals.
  • 4
    Replace the blown fuse. Go to your local hardware store and pick up a matching fuse. Make sure you check the model numbers of the fuse as well to be sure you get the right component. Install the new fuse and put everything back together.
  • 5
    Check the continuity of the circuit if you continue to have power problems. If you have a problem with continuity in the circuit, then you may have a bigger problem than just a blown fuse. Sometimes a power surge will fry a GE microwave's circuit board, which you will need to replace.
  • Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Where can I go to get a user manual for Carlton C17GSS09 microwave
    Is thisa the 39 Pound special?
    Try Curries in the UK they are cheap units made for sales as specials.
    Beware tho if they break down tjhey are considered throw away.
    Capacity - 17 litres, Microwave wattage - 700W, Grill wattage - 1000W, External dimensions WDH(mm) - 440x318x252, Stainless steel door with silver casing, Power levels - 5, Auto programmes - Defrost/cook, 8 auto cook programmes
    The cheapest price Currys for CARLTON C17GSS09 is £39.00. For more information on CARLTON C17GSS09 please visit their online store.
    CARLTON C17GSS09 is available from as little as £39.00.
    Please rate my help++++Thanks for using FIXYA
    May 19, 2010 | Microwave Ovens
    Please get me user manual for onida microwave oven- model power solo 20
    i have lost my onida microwave user manual model no 20cjs24s
    pls find and send me
    Feb 13, 2010 | Microwave Ovens
    Intruction manual needed
    Since the company seems to not even offer microwave ovens currently which, to me, is an indication that they are buying and having rebranded some Asian (Chinese or Korean) make and may not even have service information or support.
    I checked a site you may not have found that often has info available, Retrevo.
    You might want to visit and bookmark it in case they acquire what you need in the future;
    http://www.retrevo.com
    Jul 06, 2008 | DeLonghi Microwave Ovens
    Amana AMV6177 Convection/Microwave Oven Logo
    48 people viewed this question
    Top Amana Microwave Ovens Experts
    William Miller
    William Miller
    Shehu Pro
    Shehu Pro
    Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
