Question about Vizio L32 32 in. LCD HDTV
No sound My t.v is two years old and when I turned it on no sound comes out.
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
19 flat screen vizio tv with know sound
There should be some loose solder terminals at its audio output stage circuit, or have a fault with its speaker.
May 22, 2013 | Televison & Video
TV worked fine for 12 years till this evening. When I push the power button there is an electronic clicking sound inside but the set will not turn on. The speaker still makes the quiet popping sound it...
The tv has a high voltage problem, sets that last ten years or more have come to the point where a new tv should be considered, because even if you fix it there is good chance something else will go wrong, remember the parts are twelve years old.
Jan 05, 2011 | RCA F25216BC 25" TV
No sound coming out of speakers. 5 years old. When you do the surrond test just static comes out.
you may be having problems with your audio board and that could be why you dont get sound on your tv and static when you turn the sorround sound on
Jul 15, 2010 | Televison & Video
I have a 10 SEER heat pump about 16 years old, yesterday I notice that the outside unit was making a loud click noise in the heating mode. It's very close to the defrost electrical curcuit board. The unit...
Depending on make and model sounds like a check valve clicking. It can sound like it is coming from that area. You say your unit is 16 years old. Honeywell did servey on unit 10 years and older and found out they loose 25% effeicency after 10 years. You may think about changing it out. With the new tax credits you can get a 16 seer unit for the price of a 13 seer. I went from a 10 to 15 seer and my power bill dropped 40%. Rus.
Dec 03, 2009 | Heating & Cooling
Found a Toshiba laptop, about 2 years old. Screen
at two years old it is basically exctinct already and the costs of laptops coming down so rapidly you can probably go on craigslist or ebay and find a cheap laptop that is working and ready to be portable. you can also try and sell the toshiba online for parts
Sep 02, 2009 | Toshiba Satellite A135-S4427...
Set wont come on.
I don't know how that can happen when it's a year old marc. I cant' help much on that.
Jul 14, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
My Sanyo TV, 3 year old turns off with a click sound, as soon as it is turned On
Hi
your tv has defective power oscillation! the click sound that is relay power source. if the relay is click back you have defective small parts in power section! do you have experience in electronics?
Thanks!
Jun 22, 2008 | Televison & Video
Samsung TV about 4 years old, the tv turned off by itself last night and for whatever reason will not turn back on. When we use the remote the middle green light comes on in the middle as well when we use...
have u repleace the lamp yet , if not repleace, 4 years old would be a lot of hours the lamp may look intact but after severals hours tv start to go off
May 03, 2008 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
48 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
