Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
WD My Book 500g HD error. Turns off when USB is plugged in
Hey there, my HD will power up just fine when power is applied. I left it on for 2 days just to see if it would power down. It didnt.
Then as soon as I plug the USB into any computer that is turned on, it will shut itself down after blinking 3 times.
Anyone got a clue?
  • 3 more comments
  • Anonymous Aug 18, 2008
    same issue
  • finkalink Oct 27, 2008
    My harddrive does the same thing.
  • Anonymous Nov 30, 2008
    Same here on Vista and 1T HD
  • Anonymous Jan 17, 2009
    SAME HERE
  • bluesdealer Apr 01, 2009
    It was working fine until I unplugged it (properly ejected from the OSX desktop), inserted a USB thumbdrive, then removed the thumbdrive and plugged the MyBook back in. 3 blinking lights, then power down
Check the USB port on your computer. It's very likely that the problem is there. On my computer USB ports stop working sometimes and the HD does exactly that. HOwever, when i restart the computer, everything works fine.
Posted on Jan 17, 2009
When I plug in my WD 1TB drive it powers up and goes right back off. Any ideas or suggestions? It is 2 years old and has worked fine until now.
WD has had major issues with one of its chipsets (pitted IC due to thermals).
Have you tried the hhd on other machines and got the same issue?
Again, it is just a serious issue WD had with their "My Book" products.
Don't fret, the data is still on the hd and you can utilize it once you get the proper pcb for it.
Apr 13, 2011 | Western Digital My Book Essential 1TB...
The Western Digital hard drive My Book Elite does not show up on the computer screen when plugged in to the Mac computer. It has the blinking light that shows that it is thinking, and everything else...
hello
i have the same issue, exact same unit MY BOOK ELITE WD 500G ..
FYI: if this doesnt work, it is a power module (inside the black box, MY BOOK ELITE) needs to be replaced.
UNPLUG both cables from MY BOOK ELITE WD - restart your computer
- with respect to the MY BOOK ELITE WD , make sure the power cord is plugged into AC outlet wall only, and the other end of the USB into computer only -- but disconnect both from the MY BOOK WD ELITE and leave unplugged for 20 minutes .
after 20 minutes have elapsed, plug the USB cable only for 1 minute , into MY BOOK ELITE WD. Then plug the power cord into the MY BOOK WD Elite. see if it works
if this doesn't work, let the drive sit for 24-48 hours.. then repeat above instructions -- this is how i got mine to work again. FYI: To avoid this issue, i just leave the unit plugged in , while computer is running
BUT -- be aware... i use UPS (Uninterruptable power supply) to avoid power failures throughout the house. So , i suggest , if you want to leave the computer running, use a power supply to run the computer if the AC power fails..
please issue 4 thumbs up
Feb 04, 2011 | Computers & Internet
My husband has the 500G WD external hard drive which has worked perfectly until yesterday. Now when he plugs it in, the computer doesn't recognize that anything has been plugged into the USB and it's not...
Try it on another computer to see if it is working. Sometimes the USB cable can fail, too, so if you have another USB cable that fits, try it.
If it still does not work, perhaps the drive has failed.
Aug 31, 2010 | Western Digital My Book Essential 500GB...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Western digital my book essential edition 320gb no installer
try this go to comp, right click go to properties,got to devives in the top left hand corner open this go down the the bottom click on usb controllers then scan for new hardware.
Jul 31, 2009 | Western Digital My Book Essential Edition...
Using Windows Vista Suddenly can't see WD MyBook 500G
I had a problem with MY Book and I found out that if you plug the drive into a power strip it doesn't receive enough power, so it doesn't show up on Vista, but if you turn everything off and then plug the My Book directly into a wall socket, Vista will see it and put an icon in the My Computer area.
Jun 04, 2009 | Western Digital 500GB My Book World...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
500g hd
No as I have the new WD My Book World Edition 1T drive and have no problems mapping it after running the firmware update, but had to pull the power cord before starting the update because it kept saying the drive was in use, but was not.
WHOOPS!!!!!!!!!!!! Bad WD... they do not respond with common sense easy to fix answers. I can only write to the drive sometimes, but cannot delete from the drive at all. Then the next day sometimes all of the data is gone from the drive. It is just insane that a big company like WD cannot pull their Head out there *** and respond to basic BIG Problems like this with their equipment.
Good luck and best wishes to ALL! I will probably return it and try a different brand... I do IT for a living... I do not know it all, but I do know they are out of their tree for not addressing a lot of common issues on their web-site or via tech support.
I have reset, modified security settings, rebooted, etc... but no luck so far.
I have a basic intel motherboard, Q9450 CPU, 4GB of ram, internal raptor drive, Gigabit NIC connected to a Linksys Gigabit Wi-fi router via cat5 cable to the switch, and the Famous Piece Of **** WD My Book World Edition 1T drive connected to the switch via cat5 cable.
O yeah, when I first connected the best transfer was 500Kbps... After the firmware updated it is up to 6MBps... Huge inprovement if I could reliably write the data, delete the data, save files, etc. and know that the data will still be there tomorrow.
Good Luck and Best Wishes to All!
Barry from Orange, California - USA
May 20, 2008 | Western Digital 500GB My Book World...
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
608 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
