Question about Nokia N73 Cellular Phone
Calls dropped some calls are dropped When I call a number at start it is good then silence for a period of time then call is dropped
  • Anonymous Apr 02, 2008
    I agree with you
    I reloaded it
    so far it worked
    I thing the problem with Nokia software
    Problem Solver:
  • 12 Answers
You might try getting the latest firmware for your phone. Nokia's have a lot of bugs, and the new firmware releases sometimes contains a fix for them. Try to get the latest OFFICIAL release of your phone's firmware, hacked versions can be a real pain sometimes so be aware. I hope this helps.
Posted on Mar 31, 2008
SOURCE:
How do I fix?
Try with a new optical cable. You have by a branded one.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 03, 2016 | Samsung Televison & Video
Stopping the phone from ringing when trying to avoid a call you don't want to answer
You will probably have to call your phone provider and request the number be blocked, that's the only surfire way.
Aug 05, 2015 | Lands Phones
Renaultmegan 04 model fires up first time no problem but then sounds like a growling noise for a split second and only does it first thing in the morning
Hi.could be whats called"a dry start". Fit a genuine oil filter to the engine. With cheaper oil filters the oil drop back into the sump when left for long periods of time.good luck.
Jun 07, 2014 | 2004 Renault Megane
My I phone is working but it does not ring so I miss every call
Go to Settings / Do No Disturb
make sure manual is switched off. When this is enabled your calls will be silenced unless they call twice within a short period of time.
May 26, 2014 | Cell Phones
Bush 4.1 sound bar cuts out, connected via optical sound cuts out it is intermittent, happens on tv, dvd/blue ray and media player setting. Any ideas how to stop this happening. Have tried rca cables etc
I get a similar issue from my Bush sound bar. The sound drops out when the tv programme/movie etc has a period of silence in the audio track or just very low background music (no speech). As soon as someone begins to speak it starts up, but usually it misses the first couple of words. Bar is connected directly to a Samsung tv via the optical cable. Any ideas?
Aug 12, 2013 | Audio Players & Recorders
I have a samsung hf 1000 which speaks to me in chinese but i need it in english, any ideas please?
I did this to my HF1000 Handsfree device this evening as I had mine in chinese language as well today.
Power up the unit the vioce will say power on, wait for silence then push and hold the Call button, the unit will speak the pairing instructions including the pair code of 0000. regardless of the language the voice will repeat the number four times, so even thought you might not understand it, you will hear the number repeat....
After a brief silence period, press and hold the call button again, the next announcement is the language selection menu. After the announcement press the Volume + (plus) button to change the langauge, this announcement is quite long. Wait for each announcement (they are maybe two full sentences long).
Press the plus (+) Volume button to again to change to the next language, wait the appropriate length of time and press the plus Volume key again, for the next language....
Chinese language is directly after English, and so you need to go throught the key press sequence about I think five times. English, then Chinese, Italian, Spanish then German, is the sequence I believe.
Hope this helps!
Oct 08, 2011 | Samsung HF1000 Bluetooth Headset
I've been silenced for 24hrs but its been mor than 24hrs and now it says my chat is disabled how do i get it enabled
Depending on how you got it silenced in the first place, it probably wasn't the first time. For many MMORPG's, if you are banned/silenced a certain number of times (usually 3) they will permanently ban/silence you. The only way to enable it is to make another account.
Jul 03, 2011 | A Thinking Ape Kingdoms at War
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
How we will put some number on silent. i want to put some incoming call on silent mode. please assist
Depending on the phone model, to program a specific number contained in the phone's contacts for silent mode is usually done by going to the phone's contacts > highlighting the contact > selecting 'View' > selecting 'Edit' > scrolling down and selecting 'Ringer ID' > and selecting 'Silent.'
Each number for Silent Mode must be programmed individually and not all mobile phones have this option.
Incoming calls from phones not already programmed in 'Contacts' cannot be silenced automatically unless all incoming calls are silenced automatically.
Jan 26, 2010 | Nokia 5130 Cellular Phone
Nokia N73 Cellular Phone Logo
95 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
