Question about Diehl TA4180A Interval Timer
Need Instructions How can I get instructions for Diehl TA4180A interval timer?
Can timer be shut off early
I have extensive files on timers.
Your timer is not identified by those numbers.
Copy following link to view diehl timer resources:
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
Add a comment and describe timer in detail for possible identification
Jun 07, 2013 | Diehl Hardware & Accessories
HOW TO SET TIME AND DAYS SWITCHES
Copy following link for instructions setting analog timers:
http://waterheatertimer.org/How-to-set-timers.html
CU750 appears to be Mr Steam with 30 minute digital timer, or 30 minute spring-wound mechanical timer.
Copy links following links to download Instruction manuals for these timers:
CU 99216DIG timer manual:
http://waterheatertimer.org/pdf/Diehl-652-Operating-micro-II.pdf
CU 99216B timer manual:
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Apr 22, 2012 | Hardware & Accessories
Manual for diehl multi-timer typ 181-5
Timer number does not match Diehl timer numbers
1) Diehl timers and manuals appear on following links:
http://www.borggeneral.com/
http://www.borggeneral.com/diehl-control-timers.html
2) Add a comment with in-focus photo of timer posted on flicker for possible identification and more help.
Jul 19, 2011 | Hardware & Accessories
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
Oct 01, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
I lost instructions on setting the timer.
I Googled in Diehl digital timer and located a website that had the exact timer I have. Included in the list of information was a manual with instructions on setting the timer. I downloaded the instructions and set the timer. Exactly what I needed.
Jan 17, 2010 | Solar Digital Electronic Timer 20/40/60...
Diehl TA4180A Interval Timer Logo
99 people viewed this question
Top Diehl Hardware & Accessories Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Gene Haynes
Are you a Diehl Hardware and Accessory Expert? Answer questions, earn points and help others
