Question about Grilling
Kenmore Grill We hooked the grill up to the household propane line, and now it's not hot enough. We think we need to get rid of the regulator, but don't know where to find the parts, or what else we need to do.
  • 1 more comment
  • Anonymous May 27, 2008
    Grill was get hot but now is not getting above 250 degrees, what should I do
  • Anonymous Jun 27, 2008
    my kenmore grill 16234 gets to about 250 and wont go any higher. Any suggestions
    thanks
  • kmtimmon Jan 31, 2009
    Kenmore grill used to work fine, but recently it will not go above 250 degrees. Changed tank and it worked fine th 1st time, but then started doing the same thing again.
  • 32 Answers
Contact your gas co. to see if they have the correct pressure regulator , do not just remove the current one. you could try it to see if it solves the problem, but i would not advise it. you may be able to find the parts at a good plumbng supply house. don't forget the silicone tape!
Posted on Apr 06, 2008
SOURCE:
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
Converting a propane grill to a natura;l gas grill
You will need a larger gas manifold (you need more natural gas to do the same work as propane) and a new regulator. Your local grilling store should have both for around $50. But running the gas line can be big bucks and your grill is not going to be as hot - I wouldn't do it.
Jun 24, 2011 | Weber-Stephen Products Spirit EP320...
I'm going to hook up the grill to our house propane gas line and not use a propane tank. Will I need a special hook up device? Where is the connection on the grill? Thank you. Frank...
Yes Frank, you will need some specialty parts. The gas line from your tank will need a shut off valve near the grill. You cannot hard pipe the line to the grill. Code requires that your use a 12' long, rubber, Quick Disconnect Gas Hose. They are normally sold as a kit and should have all the necessary fittings. You will need to remove the grill's hose/regulator assembly, as it won't be necessary any more. That is, unless you have a high pressure propane system. Then you will need a regulator on the gas line coming from the tank to the grill. If that is the case, it should have the capacity to carry the maximum Btu output of your grill, if all the burners where ON and at their highest setting, at the same time. And finally, and probably the most important, have the knowledge and skill necessary to properly hookup an outdoor gas appliance. Or have a good friend that is a Certified Gas Technician to help you. Of course, your propane provider would probably do it for you. Which, might be money well spent.
Hope it all works out for you and Happy Grilling!!
Apr 27, 2011 | Weber Summit E-420 Propane Grill
Kenmore LPG Grill Model 141.16313800 I last used this grill 2 weeks ago and there are no problems. Yesterday I tried to use it but I can't light the grill. So I replaced the propane tank (the old one...
Relace your propane regulator, they do go bad form sitting around, had the same problem you have. you should be able to disconnect from the grill, turn on the regulator and smell the propane, if not it's bad.
Oct 19, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Gas line seems to have air trapped inside. How does one clear it?
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 07, 2010 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Can use gas for my liquid porpane grill
Yes you can as long as your home uses LPG. You can not use 2 regulators. If your outside line is after your home regulator you need to eliminate the regulator on your grill. LPG products operate on 11" of water column, that's about 1/2" PSI.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Frigidaire FD26LPDC (LP) Grill
Gas grill lights but doesn't get very hot
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Mar 10, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Grilling Logo
259 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
