Question about Dacor Dishwashers
CL Error Dacor Dishwashwer
We just installed a Dacor Standard Dishwasher; Millennia MDW24S
and ran a test cyle and in the middle of the cycle it stops and reads error CL - The manual says to close the door. We push on the door and it starts again. It appears to be closing each time we start it but then we receive the repeated CL error. Help, Please!!!
I had this problem and it was driving me crazy! I finally figured out what it was, in my case. I thought that the door switch would be the problem, so I took the door cover off and jumpered out the switch. No luck. While I had it apart, I noticed that each time I bumped the main control board, I heard a short, and heard a relay close. I found that the main control board wasn't snapped all the way into its mount on the left side. Apparently, there is a contact on the back side of the board that only makes when the board is fully seated. Snapping the board firmly into place has fixed my problem.
Posted on Mar 27, 2011
  • E A Douglas May 17, 2013
    The problem we have is not a CL ERR. It is the ERR. I need an answer to my issue. We have a large family and lots of dishes daily.
New dacor ett365 not turing on
See if any of these instructions will work:
http://www.uakc.com/Downloads/Instal/ETT3inst_3.pdf
Or try calling the customer service:
Dacor Customer Service Team
Phone: (800) 793-0093 (U.S.A. and Canada)
Monday - Friday 6:00 a.m. to 5:00 p.m. Pacific Time
Web site: www.Dacor.com
Jul 28, 2012 | Dacor Millennia ETT365 Electric Cooktop
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dacor dishwasher doesn't get dishes clean Model MDW24S
sagegril you have a good dishwasher and your problem is not new / you belong to a very large club .ans. is 120 deg at the tap iwon't get the job done . and any higher tempt is child abuse .. your d/w probley and a pot & pan setting . and hi tempt wash/ and rinse . set these to work . run the long cycle / this raised the water tempt in tank . always use fresh dergt. ( not liq ) and not what is on sale . and your dw will start working for you . m.m
Jan 09, 2009 | Dacor ED24 Built-in Dishwasher
Dacor CPS 130 oven will not heat
This model actually made this way. Sometime you can not see the thermostat because of the bracket in front of the door latch. When you remove grill panel under control panel you gonna see this bracket. It pulls out very easy. Behind the door latch you will see thermostat with red button on the middle. Before resetting this button make sure you disconnect electricity.
Dec 18, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor mdw24s
the issue is the controller board seems not to be insulated and then the glue from the connector that holds the power to the board comes apart from the heat of the wash.  I removed the board, resoldered it (power cables are the black ones) and it seems to work.  Plus I added insurlation to the front of the door (simple .5" insulation from Lowes) and now my board works a lot better.  Thus far no more CL.
Aug 04, 2008 | Dishwashers
Fisher Paykel double dishdrawer
pour some vinger in and run it thru a few cycle this will flujsh it out also if you have a hot tub supply store near you can buy a bottle of Foam Down and that will cut the bubbles down so you can wash again
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Convection Over with Dacor Millennia
We have the same issue anc alled Dacor. I seems as there is a problem with the oven as it was built with a faulty or missing temp control part. They have a fix for this problem by installing a temp control kit. you need to work through the warrantee group
Dec 20, 2007 | Dacor Millennia MOV130 Electric Single...
Dishwashers Logo
395 people viewed this question
Top Dacor Dishwashers Experts
Are you a Dacor Dishwasher Expert? Answer questions, earn points and help others
