Question about Fender Ford Tractor Suport Late Models D8nn16312ab
Hi, I have problem with tractor Ford 8210, it is
Hi I have problem with tractor Ford 8210 it is don't work function fast (rabbit) or slow (turte) operation and also it is no power on rear hydraulic cilinders. Thank in advance
2 Suggested Answers
  • 3600 Answers
SOURCE: Hi, I have problem with tractor Ford 8210, it is
check the fluid if it'd whhite then change the filters you hsve water in the oil.
Posted on Mar 23, 2010
Testimonial: "Thanks, I understand, i will check all this positions"
Why does throttle go full speed when stsrted an stays full throttle
Hi Paul:
I'd check the throttle linkage at the carb.
It may be that it is not connected or a return/governor spring has come loose.
With the engine off, check the functions at the carb when the throttle lever is moved back and forth between the slow and fast positions.
Odds are pretty good that you will find a location in the mechanism where the linkage movement does not perform the intended function.
Cheerfuls.
Apr 30, 2016 | Garden
How to check the gearbox oil level on ford 8210 tractor
Front axle middle of axle, a plug there. Front wheels hub. On outside of wheel, a plug there. Transmission, back of tractor. Sight glass, upper level.
Apr 30, 2014 | Fender Ford Tractor Suport Late Models...
Ford tractor serial number
serial number for this Ford 8210 with cab and front wheel assist is BC12163 what year was it produced?
Jan 11, 2014 | Garden
What's the meaning of the turtle and the rabbit showed in the panel.
I would say the turtle means slow and the rabbit means fast. I need more information to know what your are working on. I have these on the panel of my throttle panel on my rider mower
Aug 22, 2011 | Garden
My briggs and stratton twin cylinder engine runs good until I try to mow with it. The engine dies down and will cut off unless I disengage the mower.
If you are cutting to much grass this can happen or if the throttle control is not in fast speed (rabbit). If it is in slow speed (turtle) it will tend to die down in tall grass or wet grass. Good Luck...
Aug 16, 2011 | Garden
My ford 8210 will not move when gear is selected and the oil light is warning even although there is enough oil on dip stick. also link arms will not lift
there is a dip stick on the back end up top on the left side. It is probably low on oil.The filler cap is on the right. Use 10w 30 oil and that should sort you out. Otherwise it sounds like the hydrulic pump could be at fault.
Jan 10, 2011 | Fender Ford Tractor Suport Late Models...
What does the turtle on the dash lights mean?
Are the lights on a timer? Generally a "Turtle" means slow and a "Rabbit" is fast. Did try reading the owners manual?
Nov 24, 2009 | 2002 Ford Taurus
Does The Onkyo TX-8210 take a slow blow or fast blow fuse?
slow blow (aka time delay) fuses are used in motor circuits. Electronic devices use normal or fast blow fuses
Oct 02, 2009 | Onkyo TX-8210 Receiver
Fender Ford Tractor  Suport Late Models D8nn16312ab Logo
64 people viewed this question
Top Fender Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Fender Garden Expert? Answer questions, earn points and help others
