When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
    Genius:
  • 1,027 Answers
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Posted on Mar 31, 2008
    Sergeant:
  • 349 Answers
Smart is a hard drive checking system, it monitors the hard drives for any potential failure and advices what it finds,
i would back up all your data on that drive
hard disk 0 is your boot up disk.
do a disc check on the drive.
good luck
Terry
  • terry Mar 31, 2008
    it may be that there is nothing wrong with the drive, if that is so ,after a disc check, and you do not hold critical data on that drive, go into the bios and turn smart off.
SMART failure predicted on Hard disk 4 Toshiba: MK2035GSS-(S1)
unless you have an operating system disk a new hard drive will do you absolutely no good .
Dec 14, 2015 | Toshiba Satellite A215-S4747 Notebook
How to resolve problems (smart failure predicted on hard disk 0 : toshiba MQ01ABD050 - (S1))
Copy all the data from the drive to another drive because this one is predicted to fail very soon. Format the drive. That might work, but unlikely since SMART is a hardware problem and format is more of a software driven solution. It has some elements of a hardware issue, but not enough to fix most SMART problems. A low level format might help, but that is not a DIY.
Jul 12, 2014 | Computers & Internet
My Toshiba satellite with a mk2555gsx won't boot up no messages, tried recovery discs to no avail.
SMART FAILURE PREDICTED on HARD DISK 2: TOSHIBA MK2565GSX-(S1)
Warning: Immediately back-up your data and replace your hard disk drive.
Press F1 to continue.
What is that problem?? and how to troubleshoot this my computer, the model is neo M1110 noteboke.
Sep 10, 2013 | Toshiba MK2555GSX 250GB SATA/300 5400RPM...
Smart failure predicted on hard disk 0:SAMSUNG HM321HI-S1 lik message coming when i on the system.. so wat wat to do now?
Save all of your files to an external storage device (Flash Stick or desktop drive) and the replace the hard drive. Do it quickly, because there is no time period given before it fails. And it will.
Jun 24, 2012 | Dell Computers & Internet
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
DELL Studio 1737, last week my computer shut down and now all I have is a message that states the following....SMART Failure Predicted on hard disk 0: WDC WD3200BEVT-75ZCT2-(S1)......WARNING: Immediately...
It sounds like the failure message is saying your hard drive is about to lose sector 0. But if you press F1 it will let you continue your boot and then you can backup your computer.
You can just do the system backup to a set of DVD's as instructed by the dell restore disk creator program. I have done this for my mothers home pc and works pretty well. Then when the HD does finally fail you can replace it and reload your system with the newly made restore disks.
Oct 11, 2010 | Computers & Internet
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Error message at startup !!
SMART stands for Self-Monitoring, Analysis, and Reporting Technology.
If you want lots of details on what it is, and does, take a look at this link:
http://en.wikipedia.org/wiki/Self-Monitoring,_Analysis,_and_Reporting_Technology
It is highly unlikely that you will be able to fix this since it's a hardware problem on the hard drive. The drive may last for years or it may die tomorrow. At a minimum I would back up everything you care about on a regular basis.
If you found this information helpful I would appreciate it if you would rate this solution. I hate to beg, but over half of the solutions I've posted have no feedback. I'm not paid for this I'm just trying to help.
Dec 31, 2007 | Computers & Internet
Computers & Internet Logo
1,121 people viewed this question
David Payne
David Payne
