I have a brand new Yamaha RX-V1800 AV Receiver. I cannot get the receiver to convert 4:3 non HD channels into 16:9. I have gone to the video options set up and set the HDMI aspect to Smart which is supposed to do it. I am using all HDMI connectors (between cable box and receiver and b/t receiver and TV). The TV is a Samsung 42 inch plasma.
  • 3 more comments
  • ccain Mar 30, 2008
    I have the manual. Pages 92 and 93 are where these options are discussed. I have already read them and as I noted above I have the HDMI Aspect set to "Smart".
    Thanks for the response. What I "get" is either the dreaded black spaces on the left and the right of the picture (with the top and bottom filled in) or a "mini" 16:9 where there is a black border on all four sides of the picture.
    Regarding your 3rd bullet point, I wonder if that is my issue - how do I know what my cable box is inputting its signal at?
    Turn off the cable box and then press the menu button?
    I am not sure I understand your point about the cables at the end - I already have a HDMI cable I am using (and I have a component cable also if need be). Are you saying that because I am using an HDMI cable, this problem is not fixable? (Also the real reason I like HDMI versus component/coax/optical, is it saves me the extra cords for audio! :-) )
  • ccain Mar 31, 2008
    Thanks for all the help - regarding your recent solution - to be clear - I currently have an HDMI cable coming out of the cable box into the receiver. Are you saying (1) remove the HDMI cable; (2) use the component cable as noted above; (3) turn off both the receiver and box and do the above?
    Now, the problem with (3) is if the receiver is off, i cannot access the box. So I have to leave it on. are you saying after I do this with the component cable I can go back to the HDMI?
    OK bestdarngood!!!!! YOU ROCK!!!!! It worked, though I would note I did NOT need to use the component cable. Just went into the menu and set it like you said to 1080i and 480p.
    I AM THRILLED!!! Thanks again!!!!
  • 3,037 Answers
When “HDMI SCALING” is set to “THROUGH”, you cannot
make any adjustments to “HDMI ASPECT”.
• If the aspect ratio of the input video source is other than 4:3, this
unit automatically ignores the setting of “HDMI ASPECT”.
• When “HDMI ASPECT” is set to “SMART”, the video images
of the edge of the video monitor are rather stretched.
• When the video signals are input at HDMI IN jacks or the
signals are input with 720p, 1080i or 1080p of resolution, the
setting of “HDMI ASPECT” does not affect the video signals
output at the HDMI OUT jack.
So this is what your manual says which is exactly what you did, correct? and there is no stretching of the picture to fit the screen? or what is happening instead? A black space on the sides of the picture? Please let me know about these questions.
Thank you
Posted on Mar 30, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Mar 30, 2008
    To check how your resolution is set turn the box off and press the menu
    button on your remote to bring up the service menu. You can then change
    the resolution to any thing up to 1080I. Component cables will carry
    1080i/P however they are considered analog cable because of they way
    that they carry signal. The reason you hear this talk about HDMI being
    better is because HDMi is a digital cable, meaning it will carry
    digital signals (theoreticaly a better quality. The reason its better
    is because when your signal comes into your house it is analog. Your
    motorola box from comcast then converts it to a digital signal. If you
    use HDMi it stays that way to the set. If you use component Cables then
    the box will convert the signal yet again back to analog therefore
    giving you a lower quailty then what you would get with HDMI. As far as
    how much of a difference there is, is still a matter of debate. Some
    people can see it and some people cant. My suggestion is to by a lower
    priced hdmi cable from a local retailer. Hook it up. Then hook up your
    box with component and see if you can tell a difference. If not then
    return the hdmi cable, or use it for another one of your components
  • Benjamin Patri
    Benjamin Patri Mar 31, 2008
    sorry about that last one try this
    1.
    Make sure you have the Component Cable running from the Y Pb Pr OUT on
    the cable box to the Y Pb Pr IN on the back of the VR-20.
    2. With the Cable box and VR-20 turned off, Press the Menu button on the front of the cable box.
    3. Aspect Ratio should be set to 4:3.
    4. Press the Down Arrow until it reads "Y Pb Pr OUT", set the resolution to 1080i by pressing the Right Arrow button.
    5. Press the Down Arrow again to set Override to 480P by pressing the Right Arrow button.
    6. Press the Menu button to exit.
    7. Turn on both VR-20 and Cable Box.
    (Note:
    Override value is the resolution for Non-HD channels. You will notice
    the VR-20 switch resolutions when toggling from HD to Non-HD channels)
  • Benjamin Patri
    no problem, glad you got it fixed
    Genius:
  • 3,587 Answers
SOURCE:
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
HOW DO I USE A EXTERNAL AMP LIKE A YAMAHA M-85 FOR MY CENTER CHANNEL ON MY RX-Z11 AV AMP
You should have preamp output jacks on the back of the receiver. Hook that up to your external amp input.
Jul 24, 2013 | Yamaha RX-Z11 11.2 Channels Receiver
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Would I be able to connect Yamaha eq 70 equalizer to Yamaha av receiver RX-V1800 Thanks.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose some form of STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Apr 16, 2011 | Yamaha RX-V1800
Yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Feb 22, 2009 | Yamaha RX-V1800
Ipod connection to a Yamaha RX v363 receiver
Fortunately you are wrong :)
On yamaha site you can see that RX-V363 has a DOCK connector, which supports both iPod docking station YDS-11 and Bluetooth Wireless Audio Receiver YBA-10.
Jan 25, 2009 | Yamaha RX-V1800
Yamaha RX V-663 video output into old Coaxial TV
You need a coax to RCA converter. Do a google search, Belkin makes one, Radio Shack probably has one too.
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Cable box HDMI connection probelm
This is from the Yamaha user guide:
The analog component video signals (with 480i (NTSC)/576i
(PAL) of resolution only) are converted to the S-video or
composite video signals and output at the VIDEO or S VIDEO
MONITOR OUT jacks.
The question is what kind of signals you get from your HD cable box.
Jul 06, 2008 | Yamaha RX-V1800
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
