Question about Zebra TLP 3844-Z Thermal Label Printer
Feeding-problems Hi! I have a problem with the feeding. When I try to print a lable my printer feed out like eight lables and then comes the printing. (we use lables with the size of 10x50mm) What can I do to solve this problem? Best regards Gustaf Forsberg
  • 53 Answers
You need to calibrate. hold the feed button down intill it flashes 4 times in a row and the quickly let go. it will feed some labels to calibrate and should stop at the tear off. you also have to set label size in the driver to keep from losing calibration.
Posted on May 19, 2010
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
HP paper feeding issues
you can put only a few sheets in at once, and then push the sheet a little bit until the printer takes it, once it does that, try a few sheets at once and you should still have to make the printer take the first but after that they should all take normally.
Dec 02, 2008 | HP PhotoSmart C4280 Laser Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Printing not centered
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Sep 04, 2008 | Zebra LP 2844 Thermal Printer
Zebra 110xi plus not printer strainght across label
* do full manual calibration
* reduce the print speed & try
* set back feed as before instead of default
* try with little big labes
Jul 28, 2008 | Zebra 110Xi III Plus Thermal Printer
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
WILL NOT PRINT LABLES
Maybe you have the type of file blocked on your printer/computer. If not im not sure what the problem is..
Mar 08, 2008 | Brother HL 5140 Laser Printer
Zebra TLP 3844-Z Thermal Label Printer Logo
346 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
