Question about iRiver H10 MP3 Player
IRiver hard drive problems
My iriver isn't recognized by my computer, even when in UMS mode, except in the eject hardware menu. I hear weird sounds when it is trying to connect, and I read on this site that that is usually indicative of a hardware problem. Is there any way to fix that or anywhere I can send it in for repair despite it being out of warranty?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
Where can I get the driver and music manager for my IFP-799 ?
iRiver IFP-799 is a IFP-700 series player.
Making transfers to the device can be done in either UMS or Manager mode.
UMS firmware matches with seeing the player as a removable disk in Windows Explorer and is also used for updating firmware, using iRiver PLUS software.
Manager firmware matches with iRiver Music Manager software.
When needing the Music Manager go to next site and enter the word
manager in the second column next to GO:
http://www.iriver.com/flash/index.asp?code=0302
iriver music manager ( Ver. 3.21 ) shows up: click the item and read
the instructions for download and installation.
How to update the player's firmware
in MSC mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=47
in Manager mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=252
Need more help ? Just post a comment.
Dec 25, 2009 | iRiver iFP-799 MP3 Player
I'm looking for for a driver for i-river MP3 IFP-790 and can't find anything right on the web. would appreciate it if someone could direct me to a download link, tnx
IFP-790 can be accessed in UMS and Manager mode:
UMS mode
For firmware upgrades iriver PLUS3 must be used.
Download iriver PLUS3 going to this site:
http://www.iriver.com/index.asp
Click Support on the left side.
Select Download in the second column.
Select "Download iriver PLUS3" in the page: allow download (when blocked / sometimes download has to be repeated).
The size of the iriver PLUS3 download is 59.3 MB.
iriver PLUS3 can also be used for music transfers in UMS mode.
Manager mode
For Manager type connection the iriver music manager must be downloaded and installed.
Go to the support site:
Select Support in the first column.
Enter the phrase 'music manager' and click GO:
download 'iriver music manager (Ver 3.21)' [ 28 MB].
Sep 29, 2009 | iRiver iFP-790 MP3 Player
I replaced the battery in my iriver h10 20g. System file missing
was your player set to ums mode before running updater? to put it in ums mode you have to reset player by removing battery then reinstall battery then connect it to your computer turn on player and at the same time hold the button down with the o on it then run the updatera program again
Mar 23, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
IRiver Music Manger not recognizing iRiver player when connected
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Jan 23, 2009 | iRiver iFP-795 MP3 Player
Iriver h10 20gb not recognized in UMS
I sometimes have to reset my iRiver in order for my Mac to see it. I have an h10 5gb, to do this, I have to remove the battery then reconnect the battery. Then I connect it the usual way to get into the UMS mode. But I think with yours it has it's own reset button. If it was working and now has stopped, I would think you just need to reset it and try again.
Oct 10, 2008 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
IRiver X20 mp4 player will not turn on.
Mar 23, 2008 | iRiver X20 MP3 Player
Getting music off Iriver
Bronte,
When you change your firmware from the "manager" version to e.g. the Firmware v1.85 UMS version, you will no longer need to use the iriver manager software to move mp3's around, you can just drop them on or from your iriver. The disadvantages are that:
1. by upgrading to the UMS version, you will wipe ALL your current music, so it will NOT help you right now, only after you have upgraded to the UMS version and placed mp3's on there again. The iriver will behave like an external thumb-drive, so you can use it on any PC without the iriver manager.
2. The UMS firmware will ONLY run in USB 1.0 speeds, so it will take up to 36 minutes to fill the iriver up with 1 GB of music (or in my case podcasts).
Regards,
Robert Ilbrink
Dec 10, 2007 | iRiver iFP-799 MP3 Player
Iriver H10 "System files missing".
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
Sep 22, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
192 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
