Question about E-Machines eMachines Monitor E15T4
Radom flickering blue
Hi there, has anyone else this problem...I have an E-machines LCD 17'', and pretty much out of the box, the screen will flicker blueish, and then go back to normal. Any help would be appreciated
  • 472 Answers
Your video cable is not connected correctly. Make sure to check both ends, push in onto the connector fully, and then lock it in with the 2 twist screws on each end.
Posted on Apr 18, 2008
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
Hi, The screen flickers at the taskbar end every 2 second. Lenovo R400, 7443-TGA. This my second time using the lenovo thinkpad product with the same problem. Why lenovo screen always problem. I never.....
Hi techsyss,
I see that you are having issue with your taskbar flickering as you mentioned in the notes.
I would be more than glad to assist you regarding your concern.
>Try to reinstall your Video Drivers on the machine or poassibly update the Video drivers.
>Try chagning the resoltion on your system try setting it to a resolution that is lower than what you actually have and see if the flickering will still be occuring.
>Also try to boot into the BIOS of the machine to see if the Flickering occurs in BIOS as well, to boot into BIOS upon powering the machine keep on tapping F1 till you get a blue screen saying phoenix BIOS as long as the word BIOS is there you are in the right page. just check if the flickering happens there, if it does then the issue is not software but most likely hardware it can be the LCD itself or the Cable conenction of the LCD to the Video on the motherboard.
>if the flickering is present in BIOS most likely you will need to have the system serviced for proper repairs and diagnostics.
I hope this helps.
Have a nice day,
mvincentc
Apr 25, 2011 | Lenovo Elite ThinkPad R400 Notebook
Flickering lines on the screen
I suggest try to connect your machine to an external display and see if its having also a flickering lines, if not it means the lcd display have a problem and try to load also to BIOS and see if its also having flickering lines, if its having also flickering lines means that the lcd is faulty.
Hope it helps. =)
Apr 20, 2011 | Samsung N120-12GBK Netbook
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Half of the screen flicker but in defferent colors. Sometimes it will go half blue
The best solution for that is to take the laptop outside, and throw it in the trash after you back up all your files. Cheaper to buy a new one. Don't let anyone con you into repairing it. It needs a new LCD screen which cost more that the laptop did.
Feb 01, 2010 | Gateway Profile 5.5 Desktop PC w/17"...
My hp vf15 monitor flickers on and off when it is plugged
17-inch CRT?
Ask your friends -- one of them probably has a "surplus" 17-inch CRT that they will _love_ to give-away to you, to replace yours.
Or, look on CRAIGS LIST for a used 17" LCD screen, for $30 to $40.
Jan 14, 2010 | HP Pavilion MX75 17" CRT Monitor
The screen flickers
The backlight inverter board may be going bad or the power supply problem. Look for bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Polaroid LCD-1700 17 in. Television
My screen is flickering
firstly try reinstalling the video drivers, if that doesn't work either the inverter is ready to give up or the monitor connector has somehow worked loose from the socket
Nov 13, 2008 | HP Pavilion dv6000z Notebook
Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Jun 10, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
E172fpt Backlight flicker
It's a pretty easy fix if you can solder. Get the parts here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=220476282873
May 27, 2007 | Dell E172FPt 17" TFT LCD Flat Panel...
E-Machines eMachines Monitor E15T4 Logo
621 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
