Question about LG DLG6952 Gas Dryer
It will not heat up 2 and a half year old gas dryer works perfectly just no heat
  • LG Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 15, 2011
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: It will not heat up
LG gas dryers have a manually resettable high limit thermostat on the burner assembly. It is near the igniter and is about the size of a dime with two wires attached to it. There is a pin in the center of it which can be pushed in to reset the thermo. It usually trips due to a poor vent (poor air flow, causes excessive heat build up at the burner). Eliminate any flexible ducting, make vent as short and straight as possible, and clean out lint in vent pipe and at the exterior vent hood. Make sure the exterior vent hood has a full 4 inch distance the flap can move (not the two in low profile type) or is one of the multi louver types. You will have to take the front of the dryer off to get to the resettable thermo. (make sure the dryer is unplugged when the front is off)
Posted on Mar 23, 2010
My 2 year old Brada dryer won't heat up. The breaker is fine.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Dryers
Dryer 'runs', just doesn't develop ANY heat. We
If you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | KitchenAid Dryers
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
No heat. Elec. power OK. 12 years old
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Whirlpool WGD5200TQ Gas Dryer
Our dryer works but does not heat up. this is onl...
heatman101
May 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 500 series dryer blows cool air only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Zanussi TC180W Electric Portable Dryer
It will not heat up, 2 and a half year old gas dryer works perfectly just no heat
Mar 23, 2010 | LG DLG6952 Gas Dryer
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
LG DLG6952 Gas Dryer Logo
63 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
