Question about Polaroid One600 Ultra Instant Camera
Flashing green light
When I open the camera the green light flash continuously
  • 3 more comments
  • jamulligan Jul 18, 2008
    I have the same problem. The green light is doing a rapid flash and the camera will no longer work
  • proper91 Jan 27, 2009
    this is bull. i have the same issue. why doesn't polaroid have trouble shooting for this issue?
  • Anonymous Feb 01, 2009
    My Polaroid One 600'g green light blinks continuously and won't take picture.
  • Anonymous Mar 28, 2009
    i have a full pack of film in the camera, the green light is flashing extremely fast and it will not take the picture.
    does it mean my battery is nearly flat? or there is something wrong with the film?
    please someone help!!!!!!!!!
  • Anonymous Mar 29, 2009
    the exact same thing happens to me, and its brand new
    New Friend:
It's because the battery in the film pack is dead, you have to put in a new pack of film. you're welcome
Posted on Aug 19, 2014
I also have the same problem.
Does anyone know the solution?
Posted on Aug 07, 2008
  • pimpin_with_ Feb 03, 2012
    My camera as well :( any info?!
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Samsung digimax v800
The manual does not indicate what is wrong, when the green light is flashing, other than the flash is charging.
It could be the flash can't be charged, because the flash capacitor is defect, or the battery does not have enough power.
Try switching on the camera while not in automatic mode (M of so) or when in video mode. If the light on the main dial still flashes, I think you should look for another battery. But first try another battery, before you buy one. (Or test the camera with an external power supply. Don't forget to switch of the camera, every time you change the power supply.
Mar 14, 2014 | Cameras
Samsung camera problems
when trying to power off the camera a green light which is on the right corner blinked and the images are displayed continuously. What could be the problem?
Apr 25, 2013 | Samsung ST30 Digital Camera Pink
Nikon D90 flashing green light runs down battery even in power off mode.
Possible short to the top cover circuit around and including the on/off switch - spillage, wear of switch.
Apr 06, 2012 | Nikon D90 Digital Camera with 18-105mm...
The only sign of life after switching on is the Multi-indicator light flashing red. This continues for about 1 minute before when it turns off. I have noticed sometimes 1 or more green flashes...
Please indicate the brand and model of your digital camera. Can you remember anything that happened with your camera before you experience the problem now? Do you see anything at all at the LCD screen?
Sep 19, 2011 | Cameras
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
What is setting for continues flash, regardless of lighting.
You should be able to take the camera off of the FULL AUTO mode (the green square) and put it on "P" mode (program mode), which is full auto except for flash. Then if you keep the flash open it should always use it.
Nov 21, 2010 | Nikon N55 35mm SLR Camera
Turn on power, green light flashes, powers off
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Rokinon DZ1000 Digital Camera
Green light flashing continuously on exlimz1050
The reason of flashing is b5be3f3.jpg Thanks for Contact with us.
Feb 02, 2010 | Casio Cameras
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Polaroid One600 Ultra Instant Camera Logo
1,298 people viewed this question
Top Polaroid Photography Experts
Joseph Coppeto
Joseph Coppeto
Duke Mcadams
Duke Mcadams
Level 1 Expert
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
