Question about InFocus LP70+ Multimedia Projector
When I plug in the projector, it immediately goes
When I plug in the projector it immediately goes into standby mode with the orange light on top. Never turns on. Can't get it out of standby.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Depending on the age of the projector it is likely the power supply. If the serial # starts with ANEL5********
check to see if the main board has a green cable going from the front center of it down towards the power supply which is next to the lens. If not the power supply needs that wire to fix the problem . If it has the wire upgrade then the power supply IS for sure bad. If it is a newer LP70+ with the s/n beginning with AJNV, THEN IT TOO IS LIKELY THE POWER SUPPLY.
Posted on May 18, 2010
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
How can I reset a VT540 without a remote it has steady orange and red lights on so is in standby after bulb change
Simple.
Press the Help button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the STATUS indicator goes out.
Apr 04, 2011 | NEC MultiSync VT540 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
LP70 appears to be stuck in standby mode. The orange light illuminates immediately when the power is turned on. The bulb was just replaced.
the power supply needs to be upgraded which involves soldering a wire to the power supply then to the main board.
Jun 25, 2010 | InFocus LP70+ Multimedia Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Lg 50'' dlp tv
hi my is the same do you have a solution yet?
Feb 26, 2008 | LG DLP Projector 1400Lum RD-JT30...
Ask proxima m2+
lamp gets brighter & brighte within a minute & immidiately color wheel stops rotating & projector goes to standby mode. for 3 to 4 minutes again same symptom contimuously observed pls guide me which part is suspected
Jan 16, 2008 | InFocus ASK Proxima M2+ Multimedia...
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
No power
I had to replace the internal fuse after my light bulb burst. You can remove the case by removing the screws on the sides and the carefully slide it off. The fuse is under a plastic cover by the power plug location. I'm not sure if this will fix your problem totally though. I just installed my replacement bulb and I get the solid orange light for 30 seconds and it goes into standby mode again.
Nov 06, 2007 | Optoma H30 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
248 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
