Question about IBM Wheelwriter 30 Typewriter
Tabs are pre-set & won't clear permanently
Whenever I turn the machine on the tabs are pre-set. I clear them but everytime the machine gets turned off it automatically re-sets all the tabs again. How can I clear them permanently?
  • IBM Master
  • 3,594 Answers
You are probable in a format mode of some kind. Remove the batteries, turn off for 30 sec., this will set all to default settings.
THE MEMORY WILL BE CLEARED!!!
DickyO
Posted on May 17, 2010
Does not stitch, just beeps
try changing the needle
try rethreading the machine top -make sure to use every thread
guide & bobbin--make sure the bobbin is turned the right way in the
bobbin case
clean under the needle plate & in the bobbin area for lint
also try turning the machine off & then back on & see if that will
help
Oct 07, 2012 | Singer CE-200 Quantum Futura Computerized...
How to clear a tab setting. Have tried Code Tab set (Clear) and this does not work.
Refer to the op. manual if you still have it... if not you can download one FREE at www.nadist.com .
As a last resort you can try a complete clear...this will reset machine back to factory defaults and clear memory tho.... so if you want to try it... Switch the machine OFF. Then while holding down the MARGIN RELEASE key switch the power back ON.
The unit will begin printing a pre-programmed test page, let it run for half a line and then switch the machine back OFF. Wait 5~10 seconds then switch the unit back On and the machine will be back to Factory defaults.
Jun 30, 2010 | Nakajima AE-740 Typewriter
How do I release the set tabs
Try pressing key marked "T clr", tab clear, and then press return key.If that doesn't work, remove the AA batteries and turn machine on. If tabs are cleared, you can re-install the batteries. The only job the batteries perform is to keep your tabs and margin sets in memory when you turn machine off.
Jun 04, 2010 | Lexmark Wheelwriter 1500 Typewriter
You are probably in a format mode. You can remove the batteries, turn off the T/W, wait 30 sec., turn on. Everything will go back to defalt settings.
THE MEMORY WILL BE CLEARED !!!
Tou can get a manual at lexmark.com.
DickyO
Mar 23, 2010 | IBM Wheelwriter 30 Typewriter
I'm looking to get the pre-set patterns to play on my Korg DDD-5
A demo on YouTube shows the owner pressing one of the buttons on the left side to select possibly a bank as well as the start.. I could NOT find a manual online to download.
Jan 09, 2010 | Korg Ma30
Everytime I turn on my computer I have to readjust brightness
if you are using windows Operating system Go to control panel & click power options & set the requuired brightness.
Oct 11, 2009 | Acer Aspire 7720-6712 PC Notebook
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
Get Paper Jam everytime I print
its general problem with commen soln. just put the all pages properly & neatly in ur printer & turn on ur printer whenever u required & after finishing ur printing process turn off it everytime.Also dont give the fake printing commands it also affect ur printing process.
Dont turn off ur printer while process is running. its main reason of paper jam.
Aug 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Browser doesnt load page
Just like a computer browser, whenever you browse the internet, the G1 will download images, text, passwords, etc from all sites accessed. it places this info in a place called a 'Cache'....it can get so full it will prevent pages from loading. to fix this, clear your cache. there are 2 ways to do this.....
1: MENU > SETTINGS > APPLICATIONS > MANAGE APPLICATIONS > BROWSER > CLEAR DATA
2: BROWSER > MENU > MORE > SETTINGS > SELECT CLEAR CACHE, CLEAR HISTORY, CLEAR ALL COOKIE DATA, CLEAR PASSWORDS
after doing that, turn off and on the handheld and try it again. if you keep up on doing this everytime youre done browsing the web, it wont happen again.
good luck :)
Nov 03, 2008 | HTC G1
Faxing redial problem
Open the left fax display cover. Find and hold down the "Alternate Display" key. While holding it down, press the "Stop/Clear" key. The transmission will be cancelled.
Automatic re-dialing is preformed by this machine unless you are in the direct transmission mode.
To set the default to direct transmission:
Press the "System/Menu" key,arrow down to "Fax Default".
Press the "Enter" key. Arrow down to "TX/Default".
Press the "Enter" key. Arrow down to "Direct Feed Transmission" and press the "Enter" key.
When you are finished, press "Reset".
Mar 30, 2008 | Kyocera Mita KM-2050 Printer
IBM Wheelwriter 30 Typewriter Logo
76 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
