Question about Electronics - Others
Tannoy jupiter mk2 limited edition 60th anniversay info
Tannoy jupiter mk2 limited edition 60th anniversay speakers any info on these?
mrwtech
  • 59 Answers
SOURCE: I am not very technically
get an Ohmmeter, take a reading on each speaker line one at a time, on both A & B speaker lines. You should get a reading of 8+/- ohms. The speaker switch with the 6 spks will probably read almost 0 ohms when all 6 are running. That is what your amp is not liking. Try running it with one set of speakers on the switch,with the Tannoys on ch A on your amp and the switch on B. add one pair of the 6 at a time and you'll see that it won't like all 6 at once. 2, maybe 4, at a time is probably what you'll find to work.
Good Luck.
Posted on Dec 18, 2008
SOURCE: inverted(puhed in)tweeter
Hi George,
You may be able to pull them out using tape. That is sellotape then gently pull .They should pop out like
a dented car panel. My understanding is these domes really protect moving coil from dust so should not affect sound. Worst case swop the tweeter.
Ive just bought a pair of revolution 3 with same "fault" so I will let you know how I get on .I am in Electronics trade as profession. It may be possible to gently remove dome using a surgical blade then popping out and gluing on with PVA / Latex glue coloured with black ink if you dont like white appearance.
It is sometimes possible to pull out using fine sewing needle push in then gently pull out as if removing a spell from your finger.
Hope this helps
Posted on Mar 27, 2009
SOURCE: need to recone spker Tannoy super gold sgm10 b
I needed some speakers reconed. It ended up cheaper for me to just purchase new 10 inch woofers for my speakers. I actually purchased Rockford Subs for a car and placed them in my home speakers cabinets. It worked great.
Posted on Apr 01, 2009
  • 23 Answers
SOURCE: My Tannoy Reveal 6D Monitors
I still suggest calling Tannoy, They are usually very reasonable and will give you a fair price to service a very good product
Posted on Apr 19, 2009
  • 133 Answers
SOURCE: Tannoy Reveal 66D
One possibility is that the mute switches on your speakers have oxydized contacts INSIDE the switch - this kind of malfunction mostly occurs when the equipment is exposed to moisture and/or smog.
The most common solution is to change both switches, but they can also be disassembled and cleaned up (which is a bit more complicated and time consuming).
Another possibility is a dried up filter capacitor in the power supply or somewhere in the preamplifier section, possibly also a bad preamplifier chip but if your speakers work fine (with the exception of the mute switch noise), then the problem is more likely with the switches.
Also, check the internal connectors for any dirt, broken wires or desoldered pins.
Could also be something else, you should know i'm only assuming on the possibilities and i'm listing the most common problems i've encountered so far.
Regards
3rq8 (Triarcuate)
Posted on Jul 15, 2009
Anybody has any information about Tannoy Puma speakers
sure. what do you want to know?
cathy@speakerex.com
Jun 08, 2009 | Tannoy Fusion TS10 Speaker
Pop and Hissing after turning on Tannoy 6D
It happens, don't be upset. Call Tannoy and get an RMA # . They will repair under warranty. When you get it back it will be as good as new. Rob
Feb 27, 2009 | Tannoy Reveal 6D Speaker
My Tannoy Reveal 6D Monitors are only outputting sound from the tweeters. I'm looking for troubleshooting suggestions.
Dec 02, 2008 | Tannoy Reveal 6D Speaker
Tannoy proto j plus. . .
Don't know but I've a pair of Proto-J's for 5+ yrs as my main spkrs and they are the best I've ever had / heard (for anywhere near the $200/pr. price I paid) - you won't be sorry - I'm sure the pluses are great - But I know the Proto-J's are killer....the dave
Jul 29, 2008 | Tannoy Proto-J Plus Main / Stereo Speaker
Tannoy Saturn s10 Dual concentric problem
tannoy dc speakers are built to very high tolerances. they are very easy to damage if taken apart so i suggest you contact a specialist tannoy service shop.
i know a shop in london who sells a lot of
vintage tannoy speakers and he says very few repair shops are capable of fixing these dc drivers. good luck
Apr 19, 2008 | Audio Players & Recorders
Power Problem Tannoy TS10
Have you checked the power supply. Maybe it has died.
Oct 22, 2007 | Tannoy Fusion TS10 Speaker
Electronics - Others Logo
124 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
