Question about Maytag Neptune FAV6800AW Top Load Washer
Od error code
Neptune washer shows error code od. modle #fav6800aww
Maytag's service center emailed me back saying that I needed to purchase a magnet for the right side of the lid, even after I sent them photos of the lid. There is no magnet on the right side, so don't be fooled! The lid comes apart fairly easily. First, with a screwdriver, apply a little downward pressure and pry out the center liquid/powder holder. It is hinged on the bottom and will come right out. Next, pull out on the bottom corners and the lid liner will come straight down. Now you can verify that the magnet (on the left side!) is there and seated correctly. If that is the case, go ahead and reassemble. Unplug the washer. Lift up the top portion of the washer (at the crease). You may need a screwdriver to pry up on it. I didn't. I just pulled up on it. It comes up fairly easily. Now you can see the locks, mounted with one bolt on either side. Inspect the wiring for any wear or damage. Next, remove the locks one at a time, unhook the wire connector and plug them back in. Reassemble. Leave the lid up (not sure if it matters, but I did) and plug the washer back in. That's all I did and it worked! The "od" alarm didn't come back.
Posted on Oct 22, 2008
Washing machine would not start, just shows error code "od" - How can I resolve this?
Thanks
Posted on Dec 14, 2008
  • lhong_99 Nov 06, 2010
    If od code appears, that means at the end of the cycle, the machine considered the door was not opened even though you opened the door already but the 'end' display still on. That's why it won't start a new cycle. The easiest fix for me is to pull the little black button out (the little black button is located above the door latch).
  • gina baker Sep 15, 2012
    extremely helpful,it fixed my washer. to the exact. thank you, it was a simple task.
OK...i had the same od or OP error code and read all the posts. My wife called for a service repair and the tech said a "board" had to be replaced and that it would be $600 to repair.
In the end here's what I did to fix the issue - I pried the bottom portion of the top lid away (you can't be shy...you have to use some umpf). I doesn't completely open up but it does expose the key item - the magnet on the left side had come out of it's little plastic seat. Without the magnet in place...the door won't lock and thus the error code.
I have been using the washer for a week now (with the lid still seperated) with no errors so in a while I will seat the magnet properly with some blackmax (superglue).
I think the cause for many people's intermittent diagnosis of the problem is that once the magnet comes out of seat...it could happen (through opening/closing the door) to misalign itself one day...and the next be OK.
Good luck everyone...hope this helps!
Posted on Jul 27, 2008
I just fixed mine. 1. Remove top. 2. remove left side lock accuator. 3. open accuator case. 4. Solder small broken wire back to diode. 4. reassemble 5. enjoy.
Posted on Oct 11, 2008
  • 96 Answers
The error code od means only that the machine was run for three straight complete cycles without opening the lid. Just have to open the lid to get started again.
Posted on Mar 31, 2008
I fixed the problem on my own and I'm a little old lady. Once I figured it out, it took about 2 seconds. The lid has magnets on either side that lock the lid. Poke something GENTLY into the hole on the LEFT SIDE. The magnet gets unaligned and it just needs a little nudge to realign it. Easy peasy.
Posted on Nov 28, 2017
Read
Posted on Aug 25, 2008
6ya staff
SOURCE:
Washer will not start , od code is showing on the panel
You have lost signaling from the Left Hand Lid lock.
The OD code is sent out from the Console main control board when a lid open is not sensed via the signaling from the Left Hand Lid lock for three completed wash cycles.
Google this sticky for help with your issue ""Neptune TL Washer FAV6800AWW"" start at the 5th post down. You will find a link to the service manual and help on troubleshooting your issue.
Sep 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Code of od on washer
The Control Board has not see a Washer Lid Open for 3 completed machine cycles.
If you want to DIY this is not the best forum. Google
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky. I have troubleshooting support in that sticky for the FAV6800A and FAV9800A. I speak to troubleshooting the Left Hand Lid lock issues causing the OD error code as well as OP and FL.
Aug 23, 2011 | Maytag Neptune FAV6800AW Top Load Washer
OD signal goes on w/ neptune washer w/ lid closed. Technician said it needed control latch assembly ($105) and control board($221). Plus labor ($155). Are these easy to get and replace? Is all this...
OD error code is associated with the Left Hand Lid Lock.
If you want to troubleshoot and repair yourself Google this""
That is a repair sticky where I have DIY support for FAV6800A or FAV9800A Maytag TL's.
You do not need a lot of mechanical experience just some guidance if you wan to save your 1$K machine.
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytage Neptune TL gives od error code. Tried unplugging the machine. Tried many things, but nothing is working.
Could be loss of signaling thru the left hand Lid lock;
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Mar 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My neptune displays the od error but the door will not open. HELP
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A or FAV8800A help. You have lost signaling thru the Left Hand Lid lock.
At rhe location above tou will find common Service Repair notes for issues with the machine.
If you are going to troubleshoot you need the Service Manual.
Mar 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
It says lid is open but its not
You have lost signaling thru the lefthand lid lock
Google this "Sticky: Neptune TL Washer FAV6800AWW"
Go to the 5 post in the sticky for the Service Manual and within the Sticky I describe the issue of OP, OD, and FL error codes.
Ypu don't mention in your description but I assume your machine is throwing an OP or DO error code.
I describe how to diagnosis and repair the issue.
Jan 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader model fav6800aww has an error code od
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
2,245 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
