Question about Lexicon MC-12 Balanced Amplifier
Trouble during the upgrad of lexicon MC-12
I was upgrading my lexicon mc 12 balanced from V2.00 to V3.11getting to the step where the messege on the computer says :wait for mc12 to restart, unfortunatly we experienced an interuption of power.
Consequenses: unfiniched upgrade and message on mc 12 says
Diagnostic tests
* DEC FPGA E:001E*
And when i try to repeat the procedure of upgrading, i got the message no comunication betwen the computer and the mc12.
I tryed also to save my config in order to do the factory reset with Lexicon_Config_V160 ... ....didn t work
Know i'm stuck with that message, and can't do anything with
help me please
  • 1 more comment
  • louna_st Mar 30, 2008
    why, can't install it myself? I just wanna know what to do and i'l do it.
    the problem is not the computer but the MC12 wich is freezing on the diagnostic tests and an error message
    and i don't know what to do??
  • louna_st Apr 02, 2008
    Thx Ginko,
    Everything now is ok, you were right, the problem was the PC, so i changed it and could easelly fix the problem.
    I could restor the V2 but not the V3, no matter, i'll contact a service center ti fix it.
    So thanks a lot
  • 19,396 Answers
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
Posted on Mar 30, 2008
  • Ginko
    Ginko Mar 31, 2008
    If ypu lose power when upgrading your device sofware, you letterally fry your device firmware . The machine now is not able anymore to do post test, it won't perform startup prcedure, and it should not be able to perform normal operations.
    If you can connect the machine to same or different computer, and the amp is seen by the computer you can restart the software update and finish it, this will fix the problem.
    However it is unlikely that you can establish communication between your MC 12 and any computer if the machine is in conditions descripted above. And you cannot-home install the firmware if you cannot connect mc12 to computer, you will need to reprogram the firmware chipset.
    The only solution in your case is taking the device to a service shop and asking a firmware upgrade, they will flash your mc 12 memory with required firmware, and you should be able to use the device again, usually this is not an expensive operation.
    Regards
  • Ginko
    Ginko Mar 31, 2008
    To find nearest authorized service centre in your area contact lexicom here, providing your details and address.
    Also check this info.
    Also small rectify to above, your software is not stored on a chip, but on the HD, the result does not change, If the device does not boot to finish the software install you need to call a service to have The HD image restored.
    Regards
SOURCE:
How do I change language on pioneer deh4600bt
Section
02
Using this unit
(iPod control)
c
This unit's iPod function is operated from your
iPod.
d
(Bluetooth indicator)
Set up menu
After installation of this unit, turn the
ignition switch to ON.
SET UP appears.
Turn M.C. to switch to YES.
# If you do not use the unit for 30 seconds, the
set up menu will not be displayed.
# If you prefer not to set up at this time, turn
M.C. to switch to NO.
Press M.C. to select.
Follow these steps to set the menu.
To proceed to the next menu option, you need
to confirm your selection.
LANGUAGE (multi-language)
This unit can display the text information from a com-
pressed audio file even for information embedded in
English, Russian or Turkish.
! If the embedded language and the selected lan-
guage setting are not the same, text information
may not display properly.
! Some characters may not be displayed properly.
1 Turn M.C. to select the desired setting.
ENG (English)-??? (Russian)-TUR (Turkish)
2 Press M.C. to confirm the selection.
CLOCK SET (setting the clock)
1 Turn M.C. to adjust hour.
2 Press M.C. to select minute.
3 Turn M.C. to adjust minute.
4 Press M.C. to confirm the selection.
En
FM STEP (FM tuning step)
Use FM STEP to set FM tuning step options (seek
step settings).
1 Turn M.C. to select the FM tuning step.
100 (100 kHz)-50 (50 kHz)
QUIT appears.
! The manual tuning step is fixed at 50 kHz.
! When AF and TA are turned off, the seek step is
fixed at 50 kHz even if set to 100.
5
To finish your settings, turn M.C. to se-
lect YES.
# If you prefer to change your setting again, turn
6
Notes
! You can set up the menu options from the sys-
tem menu and initial menu. For details about
the settings, refer to System menu on page 19
and Initial menu on page 23.
! You can cancel set up menu by pressing SRC/
OFF.
Basic operations
Important
! Handle the front panel with care when remov-
ing or attaching it.
! Avoid subjecting the front panel to excessive
shock.
! Keep the front panel out of direct sunlight and
high temperatures.
! To avoid damaging the device or vehicle inter-
ior, remove any cables and devices attached
to the front panel before detaching i
Feb 08, 2015 | Pioneer Deh-5400bt Car Stereo...
My lexicon mc 12 pre amp won't power on. The lead
There may be a secondary fuse inside the unit, if not the problem will be in the power transformer, if you are handy with a digital post back and I will give instructions on testing the transformer.
Jun 09, 2012 | Audio Players & Recorders
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
I want to use headphones to listen to movies late at night - any suggestions
Buy a headphone amp at Daddy's or guitar center, connect from a line-out set of jacks in the rear,then dont use your power amp while the headphones are being used.
Oct 02, 2010 | Lexicon MC-12 Balanced Amplifier
Where can I find reliable, cost effective repair to my lexicon mc12 HD?
A place called "The Service Bench" located in Massachusetts is an authorized service center for Lexicon. Contact them.
Dan
Aug 21, 2010 | Lexicon MC-12 Balanced Amplifier
Need diagram/schematic for Lexicon MC 1 power supply
As far as I know, Lexicon schematics are only available to authorized service centers. Can you describe the problem that you are having? Perhaps we can assist you with the repair?
Dan
Aug 18, 2010 | Lexicon MC-1 Amplifier
How to install memory upgrade in Sharp Actius MC 24 ?
the other 'board' is on the mother board. contact www.4allmemory.com and have then perform a test for your compute and get recommendations.
Mar 28, 2010 | Sharp Actius MC24 Notebook
Code 12
Try entering this command "bcdedit /set CONFIGACCESSPOLICY DISALLOWMMCONFIG". If it doesn't help, you can reverse the change with this command: "bcdedit /set CONFIGACCESSPOLICY default"
Sep 02, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Lexicon MC-12 Balanced Amplifier Logo
993 people viewed this question
Top Lexicon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
