Question about Kenmore 24032\24036 Top Load Washer
How do i change coupling on kenmore washer 110.20712990
  • 15,935 Answers
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Locate the water pump. It is a small plastic pump with two hoses connected to it, directly under the front of the wash tub. It is advisable at this point to drain the residual water from the wash tub. This will save you a lot of clean up time later. Here's a helpful HINT: If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall. Connect the shop vac to the end of the drain line and pull a vacuum on it. This will quickly drain the residual water and leave you with little to no mess. If you do not own a shop vac, remove the lower hose from the pump and place a pan or a bunch of old towels under it & allow to drain.
8. Remove the water pump by removing the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and remove both hoses. HINT: This is a good time to inspect the drain lines for any debris that may have gotten lodged in the lines.
9. Install new water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly on the motor shaft. Make sure you re-install the retaining clips correctly. Insert the keyed end first, then turn and snap them in place over the pump.
10. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
11. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
12. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
13. Reinstall console.
NOTE: This water pump IS NOT serviceable. Meaning, it does not come apart. You can, at times, manage to dislodge items that have become stuck in the pump by slowly rotating the shaft backwards (with the pump removed from the washer) while pulling the object free. Sometimes this works, but sometimes the seal becomes damaged. Panty hose, underwear and the under wire from bras are notorious for getting stuck in these pumps. HINT: It is STRONGLY recommended that you use small nylon garment bags while washing some of your smaller items like this.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
My washer wont spin out
I believe these are made by whirlpool and use a rubber coupling to connect the drive motor . they are five dollars and change in half an hour if your half way mechanical.
Oct 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 11092597200 does not spin and has high pitch whining noise
I have attached a link to sears website and an exploded view of motor, pump and gear box. The weak link in a Kenmore washer is the coupling. Part number 13 in this view. If the machine is empty, you can check the coupling by unplugging power, disconnect water and lay machine on back. Or if strong help is available, pul machine foward, tip back and locate the coupler between motor and gear box. If it's bad it is time consuming but actually easy to change. If repairman is called, part $17.95, labor about $90.00. Inspect and let me know, I've changed many. Good luck.
Jul 01, 2009 | Kenmore Washing Machines
Need replacement coupling for Kenmore Washer
Go to a sears service senter and they can order one for you
Jan 22, 2009 | Kenmore Washing Machines
I have a Kenmore Series 50 three speed washer.
change the motor coupling. I had the same problem and this was the solution.
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
WASHER WILL NOT SPIN
no belt ..motor coupling..its between gearcase and motor..if you need help changing post question..but a no spin only ..i would look at mt lid switch first
Dec 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90
I need codes on kennmore elite calypso
Jan 12, 2008 | Kenmore 15864/15862 Top Load Washer
KENMORE TOP LOAD WASHER
i have the agitator dogs, but my agitator is not turning. Can you help me in getting it off. kenmore model 11022954100. please help !!!!!! wife is tearing me up!
Oct 29, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
52 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
