Question about Dryers
NO HEAT Kenmore heavy duty 80 series dryer will not heat. stopped heating in the middle of a load of laundry. never had a problem before, all other functions work. What should I check?
  • bubbalaw36 Apr 02, 2008
    On this unit, the entire back is a removable panel. I learned that there are actually three common problems that are easily remedied. In addition to the thermostat, there is a thermostatic fuse that often goes bad. Also, it is typical for the ignitor switch to need replaced, which requires access from the front of the unit. To test which device may be the culprit, simply unplug the unit from the wall, disconnect the fuse wires and attach them directly to one another. If the dryer generates heat when plugged back in after a few moments of running then replace the fuse. Repeat the same test with the thermostat wires if the first test does not bring results with the fuse. If neither test produces heat then it will then most likely be the ignitor.. All three are relatively inexpensive fixes.
  • larkar May 18, 2008
    Whirlpool Gas Dryer model GGW9868KQO (2001) Stopped heating in middle of cycle. Tub turns and blows cool air out vent. Can you describe the thermo fuse and whatever else it could be and what they look like and where they are located in dryer? Thank you so much.
    Scholar:
  • 178 Answers
On the back, lower right side of the dryer is an access panel to get to the thermostat and heating element. Be VERY careful of the sharp edges, they will cut with NO warning. Look at the heating element and verify that there are no breaks in the wire. If they are intact, I suggest replacing the thermostat. It is a fairly inexpensive part and can be found at www.partstoday.com. Let me know please if there is anything else I can for you.
Posted on Mar 31, 2008
Dryer is a Kenmore Heavy Duty 80 series electric. Runs fine but very little , and often, no heat. Is the element gone?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Dryers
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
279 people viewed this question
Top Dryers Experts
