Question about Zebra Z4M Printer
Power, pause and error lights are on. No message
Power pause and error lights are on. No message displays and nothing prints
  • 53 Answers
The logic board is blown and would need to be replaced. Have it repaired asd there is nothing you can do.
Posted on May 19, 2010
My hp jet pro 8600 won't printer it is in pause
Please download and run the HP Print and Scan Doctor from www.hp.com/go/tools to resolve the issue.
If issue still persists, let me know if there are any error messages displayed on the printer.
Apr 01, 2014 | HP D1660 InkJet Printer
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Printer is stuck on error message and pause
The printer frequently displays an error message and will have the pause light on
Jan 26, 2009 | Zebra Z4M Printer
Printer won't print, on-off light flashes on-off
I have the same issue....two flashes of the light on the power button the repeat. The carrier is clear, so I don't know what else to do. Also, when I turn the power on, the carrier goes back and forth, hitting the sides very LOUDLY! Anyone else having this issue? This printer is a few years old, so no warranty, and of course, I just bought replacment ink for it, so now it won't work..worked fine till the ink ran out this time! PLEASE HELP!
Dec 05, 2008 | Dell Inkjet 720 Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Will not print
Go to print. Prinrt comand comes up just fine. Press ok and nothing. Document pending is all I get. Printer seems to be ready but goes into power save waiting for next comand,
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer trouble
Find this in the web
http://h10025.www1.hp.com/ewfrf/wc/document?cc=hk&docname=c00489814&dlc=en&lc=en&jumpid=reg_R1002_HKEN
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Nov 29, 2007 | Office Equipment & Supplies
Zebra Mother Board's problem
The main logic board is locked and needs to be replaced.
Sep 21, 2007 | Zebra Z4Mplus Printer: Internal ZebraNet...
Zebra Z4M Printer Logo
686 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
