Question about HP w1907 LCD Monitor
Hp W1907 SHUTS OFF AFETR 2 MIN
Hp W1907 shuts off after 2 min and is not related to which computer I have it attached to it does it on all computers. Any sugestions sorry about the caps
  • 11,361 Answers
Caps in the power supply will be the first place to look, but you can have bad lamp asemblies also.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
How can i hard reset my hp w1907 monitor
Thurn monitor on as its powering up press Ctrl+ F11
to do a system recovery.
Also go to www.manualmonitor.com/hp-w1907
That will let you download free manual.
Apr 23, 2014 | HP W1907 19 in. Flat Panel LCD Monitor
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
My monitor tuens black after a few min of turning it on, how can i fix this problem?
kill killer1, May want to do some reading of this very old blog: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then return to this response and do a comment and rate it on fixya. Did it provide you with some info relevent to your w1907 problem??? 12fixlouie
Oct 20, 2010 | HP w1907 LCD Monitor
sir u should go to control panel then change the monitor timing i think u have adjusted it 2 minutes...........expand it ....... bye bye if any problem occurs mail me at vicky.akon11@gmail.com
Mar 23, 2010 | HP w1907 LCD Monitor
Screen keeps going into auto adjusment flashes every 30 seconds
Install the cd that came along
Well try to go in menu after 20 min (warming up) after powering ur monitor & try to adjust
or
U may need to press a button on ur monitor to disable the message...
for e.g viewsonic screen is button num 2
Feb 06, 2010 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
My hp w1907 monitor turns on for about a min. then back off. What is the problem
Sounds like a bad inverter. Does the screen still show that the power is on? If so, then shine a bright light at it. If you can still see the image, then you have your answer. -=/ Daft Tech /=-
Oct 23, 2009 | HP w1907 LCD Monitor
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Mar 22, 2009 | Husqvarna Garden
HP w1907 LCD Monitor Logo
403 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
