Question about Whirlpool 24 in. ADG6340 Built-in Dishwasher
Dishwasher adg 6340
When i turn my dishwasher on it fills up and after 5 to 10 mins its seems to have heated the water up and that is it, it does not want to wash or rinse.
  • ian lamb Mar 31, 2008
    Hi i hope this is the correct information for you
    Whirlpool
    ADG 6340 IX
    Type : NGPM
    Ser 33 0309 005372
    Service 8542 332 15740
    Thanks Ian
  • robert samples May 11, 2010
    open the door on your dishwasher and give me the brand and model number off the serial plate on the side of the cabnit also the water temp wont stop it from washing but a good tip is get the water as hot as you can at the sink before you start your washer
    President:
  • 1,314 Answers
Do you know how to use volt ohm meter your problem can only be two places either your timer is bad or your wash motor is bad un plug the wire at the motor set meter to volts take the connector after the water fills have some one turn the timer for you slowly if you get proper volts on your meter then open the door plug the connector back on the motor if the motor starts then the timer motor is bad if the wash motor doesn't run then its bad if you don't get no volts the contacts in the timer are bad now some timer motors can be replaced with out having to replace the whole timer
Posted on Apr 01, 2008
    New Friend:
  • 136 Answers
Is this a digital washer? If not turn the knob manualy while the bar is switched to on and see if you can get it running
Posted on Mar 30, 2008
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
My whirlpool ADG 7540 dishwasher is not heating the water but is running through the programme
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Filling and running for 2 mins, discharging all the water then signalling that the cycle is complete Model is ADG 7460
This sounds like the heater is faulty. Try running the dishwasher on a rinse cycle- if this cycle completes as normal then this would prove that the heater has gone. If not please get back to me
Jun 12, 2010 | Whirlpool Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just...
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Aug 02, 2009 | Dishwashers
Front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool ADG 6340 Dishwasher
What flashing are you referring to ? This could very well be a fault code.
Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool 24 in. ADG6340 Built-in Dishwasher Logo
445 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
