Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag MAV6057AWW Does the front panel come off and if so how?
  • 145 Answers
There are two clips under the front of the lid that have you have to push in while lifting the lid. Then you can get to the two screws behind the front panel.
Posted on Apr 24, 2008
SOURCE:
How do I remove the front panel of maytag LDE7304ACM?
Type Maytag LDE7304ACM remove front door into YouTube and see if the video comes up, thanks!
Feb 20, 2015 | Maytag Dryers
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Maytag mav6057aww leaking underneath
What I would do is pop the top of the washer, do this by pressing the clips in between the top and front of the machine, and then remove the front by taking out the two screws, one on left and right inside on the upper corners. These are normally 5/16". Lower the top after you take the front off and turn the machine on. Now you'll be able to isolate your problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | Maytag Washing Machines
Maytag P MAV6057AWW Even though the machine is level when it spins causing the floor to vibrate. The tub seems to move more than it normal would when force is applied. Thought about the damper pads,...
Hi from retired Englishman in France,
I am presuming, rightly or wrongly, that this is a front loader? I'm afraid I cannot tell from the reference.
If you are sure 1) that the machine is definitely balanced/level and that the 4 feet are equally firm on the floor and 2) the tub CAN be moved more easily than it should then it could be the dampers/shock absorbers. The bearings I would think would let you know that it/they are worn by the noise. I wouldn't expect them to go quietly!
Questions to ask are how old/used is it and has it been subjected to excessive unbalancing previously that could cause a damper to fail?
If your husband is confident and it IS a front loader have him take the back off WITH POWER OFF and visually check the damper(s). That should lead you in the right direction. Hope this helps but it is more difficult at a distance with this type of symptom.
John C
Jan 25, 2011 | Maytag Washing Machines
Top Loading Maytag washer will not rinse/drain and spin.
you may have a locked up pump causing the motor to not run, check to see if you can turn the belts under the unit, if so then you might have a timer with a burnt contact.
hope its the pump as it is cheaper then the timer to replace.
Nov 02, 2008 | Maytag Atlantis MAV7551 Top Load Washer
How do you install a thrust bearing on maytag model MAV6057AWW
lean washer back remove dust cover remove c clip holding pulley on ..good luck getting back together ..c clip can be difficult due to lack of clearance ..be sure you put bottom washer back on
Jul 22, 2008 | Maytag Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Maytag Top Load Washer # MAV6057AWW
I have the maytag MAV6057AWW. I had the same problem and today i am discovering that others are having the same problem i was. It first started with the no agitation after the rinse cycle. I emptied out the water and clothes etc. I lifted it, took it apart practically and discovered all was ok. I couldnt figure it out because after putting it back together it worked properly. After a few days it didnt agitate for the wash cycle after filling up with water. I was confused. But then I got pissed of and I slammed the lid shut and it began to work.
It was the switch. I havent replaced the switch, but i have learned to cope with the fact that i have to open and close the lid a 2 or 3 times times before it goes into the cycle.
When it doesn't agitate, its not a mechanical problem, but a safety switch that is failing to close. So either replace your switch or play with the lid a bit.
Nov 27, 2006 | Maytag Atlantis MAV7551 Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
181 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
