Question about Nintendo Wii Console
My wii will not turn on
Before when my wii was working it showed a blue light now it wont turn on
  • 2 more comments
  • davechrissy May 27, 2008
    the last time I used it it worked but now it wont turn on. We have unplugged it unhook the cords & hooked it back in & it still wont turn on.
  • Anonymous Sep 15, 2008
  • Anonymous Mar 19, 2009
    i was using my wii an it was working, I tried to the change game and it wudnt turn off!! i unpluged it an plugged it in an now it wont turn on!! Need help!
    I walked out of the room and when I returned the system was off and would not come back on.
  • 33 Answers
Fiend your solution direct from nintendo. Here is your solution....
Posted on Mar 21, 2009
  • 84 Answers
Kk your wii has some thing wronge on the inside you will have to take it to the store it came from if not call tech support and ask them, you may have to mail it to them for repairs also i had too
Posted on Mar 30, 2008
Wii has no power whatsoever going in
The button has to be pressed until you see the light come on try using the wimote power button on the upper left corner hold it until you see the light if its yellow its in standby if its green its on you should see the disk entry area turn blue a sec when it comes on. Then it should be green on the power light if no lights in just a couple or 3 seconds holding it down you may have 2 bad wii's in a row. If you take it back ask them if they have a test model on the floor and tell them to show you exactly how it works to power on and off.
Dec 02, 2011 | Nintendo Wii Console
I have a wii balance board, the batteries ran out so i changed them -now the board will not work. Ive tried pressing the red buttons together but still no joy. my neighbour is having the same issuses. Why...
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete
click here to download repair guide if u need
Dec 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
My wii works but my controler dosent show up on the screen but the buttons work i need help
I don't know about the Wii but I know what happens with the light on the Wii
Green - The Wii Console is on
Yellow - You are connected to Wiiconnect24. It's harsh not to keep the "Yellow" light on because it could overheat the Wii Console. So if it's "Yellow", put your finger on the "Power" Button and keep it there for a long time. When you push it, it will start with Yellow then turn to Green then keep the finger there for a while then will turn to Red
Red - The Wii Console is off
Blue - You are connected to Wiiconnect24. When it turns Blue, It means you are getting a message from the Wii Console or on Standby Mode
Feb 06, 2010 | Nintendo Wii Console
Havent used board in a while now wont start up. changed batteries didnt help. flashes blue but doesnt stay on
It likely needs to be resync'ed since it hasn't been used in a while. The flashing lights show it is trying to connect to the Wii...if they never turn to a steady blue, it never connected. A sync should correct the problem.
First press the red "sync" button on the front of the console, then inside the battery door of the Balance Board. The results should be immediate. If the board never holds a steady blue light after trying to sync, you problem is something else that I couldn't guess!
I hope this helps!
Jan 04, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii wont turn on the power does not show a light
Try a different outlet to make sure the outlet you have it on is good or not.
If a different outlet didn't make it turn on then at that point, try another ac adapter for the Wii. If a different adapter doesn't work then you know the main board inside of the Wii is bad.
Aug 08, 2009 | Nintendo Wii Console
My wii fit board blue light will start flashing but will not stay on.I have replaced batteries but still wont work.
test it on another wii, if you cant then call Nintendo support, it depends on the blinking really.. its probably doa... dead on arrival or something,..
Jul 29, 2009 | Nintendo Wii Fit for Wii
Sensor bar
have you paired up the sensor to the wii, maybe faulty batteries?
Jan 25, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Discs wont register on wii system, remote wont work either
You need to sync the remote with the console.
Remove the battery cover from the remote and press the red
button until the blue lights start to blink. At the same time,
press the the red button to the front of the console.  You
can access this button by removing a small cover on the front
of the console. This will reset the machine and you should
start to see th cursor in the tv screen. Repeat this if necessary
and you should be on your way. Good luck
Sep 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
