Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Briggs and stratton engine on my lawn mower won't start.
I hit a rock and now it just backfires, I replaced the flywheel key which was not broken, now i heard there is a timing gear key that may be the problem? Is that a major repair? Could the problem be a blade key?
  • nikehercu267 May 16, 2010
    I will check the blade keyway, however the engine model number of my mower is 31P977 type 0635-e1
    20 HP It has two blades. The left side blade is the one that hit the rock. Thank you very much for your help.
How to change the pto oil seal on a 18.5 hp b&g
Posted on Jul 20, 2010
  • 10,319 Answers
Remove the blade and check the keyway. If the key way has the shear pin still in it it may have been bent and not sheared off. That will cause it to be off timing. I would imagine the valves got bent from the sudden stop of the engine as well
Posted on May 16, 2010
Briggs&straion small eng, wont start its backfiring out exh,
you hit something and sheared the flywheel key which has thrown off the timing. replace the flywheel key and you should be good
Feb 24, 2013 | Briggs & Stratton Garden
Briggs 20 hp engine runs rich and backfires
Backfiring and running rich? It sounds more like the engine is running lean. Your problem sounds like a fuel problem rather than an ignition issue. However, did you by any chance strike a rock or something solid while mowing? The reason I ask is because you replaced the flywheel key. Another possibility is that the crankshaft has been bent and that could also cause the problem you are describing.
Jul 20, 2012 | Briggs & Stratton Garden
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
Hit rock and stopped mower. The blade isn't bent or loose but the mower will not start. It turns over seems to almost catch but not quite
If it hits somthing hard enough it will shear the flywheel key, which will knock the ignition timing out, to replace the key you will have to remove the flywheel, there are special pullers to aid removal of the flywheel, these can be purchased from your local Briggs dealer.
May 12, 2012 | Sears Garden
Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
May 03, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
When mower is cranked, the enigine spits and sputters and balck smoke comes out from the side.
Did you hit something hard with your mower; like a stump or a rock? It sounds like your timing may be off. There is a key under the flywheel that is designed to break off if you hit something so that it doesn't bend the crank shaft on your mower. If that key breaks off, your mower will go out of timing and spit, sputter and backfire when you try to start it. Best of luck to you.
James
Aug 25, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Hit a rock now won't start
You have sheared or partially sheared the flywheel key. It must be replaced in order to run.
Aug 09, 2011 | Briggs & Stratton Garden
Runs rough and kicks back when pull starting
The timing may be off. Has this mower ever hit anything while running. There is a small aluminum key that keeps the engine in time (flywheel to magneto) and it breaks if the mower blade hits an immovable object (rock, tree stump, meteorite etc.) The timing will be skewed and symptoms like yours will result.You can check the flywheel key by removing the cover on top of the mower and the starter/recoil unit.The key is in a slot on the top side of the crankshaft and fits a notch inside the flywheel. Look carefully. If it is sheared, the notch in the flywheel will NOT be lined up with the notch in the crankshaft and a new key will need to be installed after removing the broken one.
May 04, 2011 | Briggs & Stratton Garden
Engine won't start and backfires
Did you loosen the coil when you changed the key? Check the setting between the flywheel and the coil. !0,000ths, I think.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Backfires through the air cleaner
This usually means a bent or sheared key in the flywheel. Remove the shroud exposing the flywheel buy a 6" flywheel puller and remove the nut for the flywheel and attach the three jaw puller remove the flywheel and replace the flywheel key. The only other thing that causes this popping through the carb is a burnt intake valve this is a job for a lawn mower shop.
Sep 30, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,267 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
