Question about Mantis 2-Cycle Tiller
I have a mantis 2 stroke rotavator that is around 5 years old with the new style sv6 carb,when i am rotavating the garden at full throttle,every now and again it coughs and splutters with a puff of blue smoke,i have ran it at 50-1 mix and also ran it rich with a touch more oil but the poblem still persists
  • 246 Answers
SOURCE: looking for a manual on a partner 5.5hp front tine
Hello mellon1:
You can Donload a Manual from this Site Addy; http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=B042B784F1FA25BE93B4077C16B4408F
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 376 Answers
SOURCE: difficulty adjusting carb for smooth idle and full power tilling
Your quickest fix for this problem is to simply replace the carburetor, a Zama K54A. Do it all the time. After that, if you can find a 2 cycle oil, Opti-2, it's the best you can use and it's a one mix for all your 2 cycle equipment (blowers, trimmers, chainsaws, etc.) It's the only 2 cycle I sell in my shop.
Posted on May 13, 2009
wadembly
  • 489 Answers
SOURCE: points replacement on a flymo rotavator with a ducati engine
you can replace the points take the points out & take them to a local small engines shop the might be able to match them up with new ones
Posted on Jun 08, 2009
SOURCE: wanted help on a westwood geni rotavator any one
no i still havent found a fix
Posted on Oct 05, 2009
HarrisonFire
  • 3 Answers
SOURCE: four cycle mantis/honda engine gettting oil in carb and smokes
Honda GX25 GX35 manual on PDF.
http://www.smallenginewarehouse.com/images/manuals/GX25-35.pdf
Posted on May 30, 2010
Hwo convert the magneto on my garden rotavator to total loss ignition
whats a total loss ignition? I've been a tech for power equipment for 0ver 30 years and have never heard of it.
Feb 28, 2017 | Garden
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
Hi, I have just been given a rotavator with a briggs and Stratton engine, don't no anything about it, how old, how to start it, it has pull cord but nothing?? model number is 140202, serial is 37634 and...
Look at the: Model, Type and Code numbers. The first two numbers of the code should be the year the engine was made. What problems are you having?
Jul 30, 2013 | Briggs & Stratton Garden
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
How do you start a 2 stroke Mantis? I lost the book. Will
first, push the primer bulb a few times to get fuel circulated and air out of the carb. Turn on the switch, put the choke on full. Pull the rope until you hear it fire. Then put it on half choke. Pull the rope; it should fire within a few pulls, and should run. Take the choke the rest of the way off once it's running well. This is a standard starting procedure that works well for every kind of 2-stroke engine used in the garden.
Mar 28, 2010 | Mantis 2-Cycle Tiller
Points replacement on a flymo rotavator with a ducati engine
Jun 08, 2009 | Garden
My Mantis Tiller 4cycle engine starts well but when I press the throttle completedly, the tines turn very slowly. This is a brand new tiller, used only twice. The engine is sitting all the way down on the...
I had same issue with my 2 year old 4cycle. Check if the carb is moving full stroke with throttle movement. I had almost no movement at carb at full throttle, found the trigger in throttle handle was cracked and bent rather than pull cable. I called mantis and they promptly sent a new handle bar ***'y with new cable, throttle ***'y Etc and that solved my problem.
BTW: If you cannot wait, I did figure out that if I pushed the carb to open with the throttle trigger fully pulled it would run at high, but when you let go.....LOL
Rich in Wethersfield, Ct
May 10, 2009 | Mantis 4-Cycle Tiller
Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Mar 21, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
131 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
