Question about KitchenAid K45SS Classic Stand Mixer
Leaking "oil" (?) from motor down toward beater
Ongoing problem getting worse. Leak is mostly dark brown oily stuff. I have not oiled the motor or done anything to try to solve this problem except to continue to wipe the "faceplate" above the beater.
There also is what appears to be a little rusty looking rim around the mixer head.
Anything I can do? Mixer is about 8 years old. Bought new.
  • carolynb108 May 17, 2010
    Anyone got any other ideas? I really don't think that moisture in the motor is the problem. The mixer head has not been submerged or wiped off with drippy cloths.
  • 2,069 Answers
All you have to do, is to perform some service on your mixer. i suspect some oily must have entered. I can try to lead you through the process but Kitchen Aid is not an easy machine to repair and some parts are broken easily if not removed properly. First remove the chrome ring near the drive shaft. There is a pin that has to be removed next to the main drive shaft. This has to be driven out. Then remove the four screws that hold the unit together. You will probably find that there is a plastic gear that is stripped and you will have to drive out the pin that holds the assembly together. Remove the shaft and gear. do some cleaning, then reassemble.
Regards
Posted on May 17, 2010
  • Muzahura Frank May 20, 2010
    I hope my solution above was of some help...
  • carolynb108 May 21, 2010
    Thank you! Your instructions were very good and with the rim off I certainly found the source of the oil. I'm cleaning and thinking that will solve the problem (at least for another few years!)
    Carolyn
    P. S. Makes me mindful of the mess along the Gulf coast. I've been hearing a lot about cleaning up oil leaks lately.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. The problem is moistue getting into the case. Be careful when whiping the macine down as if you get water into the case it will rust inside and eventually cause the rusty water to run out. You can try using a hair dryer to heat the top of the case real good till all the moisture is out it will take some time but it should work to get the moisture out.
Posted on May 16, 2010
  • carolynb108 May 16, 2010
    What about the oily stuff? It is leaking to the point of dripping down toward the beater (& soon into the bowl). The rust isn't that bad, and seems like a hair dryer would make the oil drip more freely.
  • Heath Moyer May 17, 2010
    The problem is the moisture in the motor housing you will need to use something to dry the moisture out of the case like a hair dryer. I didn't mean use the hair dryer while makeing food with the beater but when it is not in use use a hair dryer or something to get the moisture out of the case then next time the moisture and oil will not come out whne you use it next.
Why is oil leaking down into the mixing bowl on the Hobart HL200 Mixer
There is a leaking gasket. The OIL is from the Grease applied to the gears. It may have somewhat turned a portion of lube to a liquid state due to heat within the motor housing during use. The OIL as you put it, could also leak out from the port where you insert the beaters. If so there is also a set of seals to prevent that from happening, and if they are worn or damaged, leaking can occur. This unit needs a professional serviceman to fix the problem.
Feb 03, 2015 | Hobart HL200-1STD Mixer
Mixmaster is leaking oil from the beaters
Here is a link on YouTube. It may not be for your model but it can give you an idea: http://www.youtube.com/watch?v=8eKHVvNX5eY
How to Fix KitchenAid Stand Mixer That Is Leaking Oil
Apr 04, 2014 | Food Mixers
Oil leaking from the attachment head
The grease leaking out of the KitchenAid mixer can be a common problem. Here is the cause, and how to fix it, and prevent this issue from happening in the future.
The KitchenAid mixers use a Benalene 930-2 grease inside of them. It is a dark, thick grease that can break down and leak out of the mixer. The grease is a non-toxic vegetable based grease, basically it is a food grade grease. Over time, or if you do not use your mixer often the grease can break down, so it would appear that there is oil leaking from the mixer. It is most common for it to leak from the beater shaft (agitator shaft) and from the drip ring.
What you need to do is take the mixer apart, clean out all of the old grease, replace it with about 6 ounces of new food grade grease (http://www.mendingshed.com/kagrease.html). It is also recommended that your replace the o-ring on the center shaft (http://www.mendingshed.com/67500-55.html) and the gearbox gasket (http://www.mendingshed.com/mixergasket.html).
To prevent the grease from breaking down in the future if you do not use the mixer very often, it is recommended that you pull the mixer out and run it for about 2 minutes every 3-4 weeks, this should stop the grease from breaking down as quickly.
Please let me know if you have any questions.
This applies to mixer models, K45, K45SS, KSM75, KSM90, KSM103, KSM110, KSM150, KSM151, KSM152, K5, K5A, K5SS, KSM5, KSM50P, KP50 AND KPM5
Thank you,
Colleen
Customer Service
MendingShed.com
customerservice@mendingshed.com
800-339-9297
Apr 15, 2013 | KitchenAid KSM150PSGR - Artisan Series...
Beater hard to remove...oil leaking out of the place where you insert the beater
The agitater shaft that the beater attaches to is bent and needs to be replaced. It's easy to do . You should replace the shaft , pin, and seal above it. You may also want to replace the part the shaft mount through, to stop oil leak. You can google the model number and find a parts breakdown for the part numbers .
Aug 26, 2011 | KitchenAid 32685 Mixer
Where the beaters fit in, there is a small oil leak when using. It will probably get worse. Bought in 1996
Oil leaks are common. As oil is stretched it separates. If it is leaking over your nice silver "beauty ring" then the ring is not catching the oil. If it is leaking below the silver "beauty ring" then the gears in the planatary area has worn down too much and is separating.
In either case, you can wipe it up with use or do what a lot of DIY people do, take her apart and remove and regrease the unit. Search online for regrease kitchenaid mixer, I would post a link but I dont want the link to be broken down the road. There are tons of tutorials for it online. You remove the grease and replace it with new. I used automotive grease from autozone, but there is a specified grease for the mixer on kitchen aid's site. Depends how picky you are.
Kitchenaid does not grease under the planatary from factory anymore, they just dont see a need. (this is an area below the silver beauty ring I mentioned. It was metal on metal when I took apart my new mixer for check up. This may be why you have grease leakage too, it was an old standard to grease there, but there is not significant friction to warrant the heavy grease there anymore.
Hope this helps.
Apr 17, 2011 | KitchenAid K45SS Classic Stand Mixer
My KSM150PSS Kitchen Aid started leaking a brown oily substance from under the large metal ring that surrounds the rotating part that holds the beater "peg." What is going on? Can it be fixed?
Kitchenaid says to run it on high speed long enough for it to warm up well, then turn it upside down- I'd leave it upside down overnight.
The grease in the gearbox, over time, will separate into oil and heavier grease- mixing them together again and letting them run back to the top of the gearbox should take care of it.
If not, come on back and we'll go through the whole disassembly procedure.
lp
Dec 29, 2010 | KitchenAid KSM150PS Artisan Series Stand...
K45SS leaks lubricant
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
The solution?...the oil leak is a very common problem with the kitchen aid mixer. If you don't use your mixer a lot the gasket dries out and the gear casing oil leaks. Doesn't that sound like a tasty ingredient to add to your cookies?? You'd think that a gasket wouldn't dry out so quickly...but it does. You'll spend about $125 to get it fixed at a shop. If you seach the net (consumeraffairs.com) you'll find hundreds of complaints just like yours....and mine. Kitchen Aid's response is basically tough luck, we got your money.
Sep 14, 2008 | KitchenAid KSM150PS Artisan Series Stand...
I went to Kitchen Aid'sKitchen Aid's web site and had an on line chat with a tect support person name Jessica. She told me that if the mixer is not used a small of oil will leak out. to fix the problem you must run the mixer for a few minutes every month or so. This seems to work.
Rick
Jul 28, 2008 | KitchenAid K45SS Classic Stand Mixer
Leaking oil
thats the planetary seal thats leaking.the seal is cheap its the labor that may be costly.is it just a nuisance leak or a lot?you dont want any oil to get in your mix.
Aug 16, 2007 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
150 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
