Question about Olympus FE-170 Digital Camera
Pictures of people have halo effect/double vision
My camera worked perfectly until this summer. Then pix started coming out almost in silohuette, with pinks or an outline effect. I had been trying to use the Red Eye feature so I thought maybe I changed a setting by mistake. The problem has persisted and people now come out almost double vision with a halo effect.
Can this be fixed or is it a setting?
  • brownr Jan 28, 2009
    yes I get a dark halo around the person when using flash in poor light and would be glad if you could help.
5 Suggested Answers
SOURCE:
poolseman
  • 206 Answers
SOURCE: Camera will take picture, but when viewed they are a strange colour.
This sounds like the first signs of CCD sensor malfunction. If this is correct it will get worse and pretty shortly you will have no image at all in capture mode. Have a new sensor installed and camera will work fine.( btw this is a common fault effecting all makes of digital cameras and v-cams ).
Posted on Sep 04, 2007
sumthin
  • 71 Answers
SOURCE: pink screen on camera
Might be Montazuma's revenge. JK
RMA if under warranty. If not call a qualified shop for a quote.
Regards Paul
Posted on Jun 11, 2008
MJS_1
  • 150 Answers
SOURCE: Whats wrong?
1) Reset the camera
2) Turn it off and remove the batteries.
3) Try to turn it back on without the batteries, to drain any
residual energy within the internal capacitors.
4) Check the battery terminals for any dirt or corrosion,
scrape clean if necessary.
5) Check the batteries, or better yet, get new ones
and put them back in.
6) Turn the camera back on to see if it woks.
7) Try a different memory card.
If that does not fix it, you may need to take it to
a professional repair shop who are equipped to
service this model.
Get an estimate first, to make sure its worth it.
Digital cameras get better with time and lose value
very quickly.
Martin
Posted on Nov 12, 2008
SOURCE: I've had my Olympus FE-340
WHEN I TRY TO TAKE PICTURES WITH MY OLYMPUS FE 340 THE SCREEN JUST GETS DARK, BUT WHEN I VIEW OTHER PICTURES THAT WERE ALREADY IN MY CAMERA THE SCREEN DISPLAYS THEM JUST FINE...CAN ANYONE HELP PLEASE?
Posted on Jul 13, 2011
Why is my summer baby monitor fuzzy on night vision?
I would say that your IR sensors are burning out. Turn the lights off and look at the camera. A bunch of small red lights should be coming on . You will see which ones and how many are burned out. There are a couple of fixes but the cheapest will be a new camera.
Jul 26, 2014 | Summer Infant Slim Secure Baby Video...
Red discoloration coming across the television
The Y-Sustain PCB is Failing.
It will require replacing soon.
The PCB does have some adjustment pots on it, if you were to take the TV to a repairer they may be able to "adjust" the halo effect out.
But the board will still fail.
Sep 06, 2009 | Vision HDV-42P2 Television
Nikon wont download pix
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.
Mar 04, 2009 | Nikon Coolpix S210 Digital Camera
WHEN I WANT TO DOWNLOAD THE PICTURES I ONLY SEE DARK FRAME IN DISNEY PIX
this camera only takes picture in the sun if you take it in a dark place it will not show up it will just out all black
Oct 04, 2008 | Disney Pix Micro Digital Camera
Double Vision
The convergence ICs need to be replaced both of them at the same time they are STK392-040 you can get replacment ICs at the following link and they provide free instalation instructions with pictures so you can do the repair yourself.
Heres the link.
http://servicemanuals.vstore.ca/
Jun 29, 2008 | Akai PT4298HD Rear Projection Television
Hannah Montana Camera, says there are no pictures on camera to download
Depending on your operating system the downloader program may not work.
1. Open 'My Computer' or 'Computer' on Vista and connect the camera to the PC.
2. Watch the screen for a new "Removable Disk" to appear.
3. Double click on the "Removable Disk".
4. Double click on the folder "DCIM".
5. Pictures will be located in the listed sub-folder. This should be named "100IMAGE".
You can then drag and drop or cut and paste them into the My Snapshots folder located in My Pictures.
May 26, 2008 | Disney Pix Click Digital Camera
Cant download photos?
My daughter just received one of these camera's for her 6th birthday and is extremely excited. I am running Windows XP and was getting the "No pictures on camera" error. I tried downloading the drivers for this but that did not work. Here is what I did to get the camera working:
1) Connect the camera with the provided USB cable.
2) Download the latest driver from the Digital Blue web site: http://digiblue.com/customer-service/downloads/index.html, select the "The Disney Pix Micro Drivers for WIN ME, 2000, XP"
3) Install this driver, this will not enable the camera to work yet.
4) After this driver has installed, go to Control Panel
5) Select System
6) Select the Hardware tab
7) Select Device Manager
8) Find the device in the list (mine said "USB Digital Still Camera"), will probably have the yellow exclamation mark on it saying that it is not working.
9) Double click the device
10) Select "Reinstall Driver" from the General tab
11) When asked if Windows can connect to Windows Update to search for software, select "Yes, this time only" and click Next.
12) Choose "Install the software automatically" and click Next.
13) You should get a message saying the driver for the "DB CIF Cam" has not passed the Windows Logo testing, select "Continue Anyway".
14) Click Finish.
15) The first time I did this, I needed to take a picture while the camera was connected to the PC.
After doing this I am able to download the pictures and everything works great. I hope this helps.
Dec 27, 2007 | Disney Pix Micro Digital Camera
Stripes on the photos
Hi if you had not chosen any fader effect then problem is with internal circuit. the blanking lines are visible kindly first chek with fadder effect in setting if it is normal then you need technical expert to physically chek the circuit. thanks Sangita
Jul 08, 2007 | Polaroid i832 Digital Camera
Olympus FE-170 Digital Camera Logo
472 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
