Question about Vacuums
Melts the bag and won't seal
The Seal on the upper lid is melting and melts the bags so it won't seal. Can I get a replacement seal for VS150?
    Problem Solver:
  • 12 Answers
If your vacuum cleaner gets hot enough to melt it's own parts, i think you have a problem. exesive heat could indicate a serious problem and might also cause a fire. try having it checked by a repair shop because replacing the seal and continuing to use it might be dangerous.
Posted on Mar 31, 2008
My seal a meal won't seal the bags. I have tried using premade bags and hand cut bags. It sucks the air out but will not heat up to seal.
There is either a blown fuse in the heater circuit or a bad heater filament, you can take it apart to see but there is no diagram or parts list on something like this, replace it.
Dec 09, 2016 | Vacuums
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 | Vacuums
Why my foos saver is not sealing
I've found with mine I have to hold down firmly on the top while unit is heating the bag to seal it. I continue to hold the lid down for about 10 seconds after heating stops until the seal cools. Hope this helps.
Sep 09, 2014 | FoodSaver Smart Seal Vacuum Sealer V3825
Outer Oreck xl bag is full of dirt
Make sure that your bag is pushed all the way past the lip on the connector tube and that the "U" shaped part of the plastic assembly is in it's slot behind that lip, or it will not seal properly and you will get dust into the outer bag.
Mar 21, 2014 | Oreck XL2200 Bagged Upright Vacuum
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Kirby upright smells like a foot. Changed the bags. We had to move it to the garage for storage beacuse it made the closet smell like bad shoes. Gets strong when used
Check the brush for accumulated hair, and other debris. If the brush is belt driven check the condition of the belt, over time the rubber deteriorates and melts when heated up during use creating a burning rubber odor.
Feb 24, 2011 | Kirby G6 Bagged Upright Vacuum
I purchased a Seal-A-Meal roll to make my own bags but can't figure out how to use it. I have a model VS108. Is it possible to seal without vacuuming?
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Jan 03, 2011 | Vacuums
I have a canister vacuum. I replaced the bag and now can otn get a good suction. Could it be the rubber seal near the bag?
The case that encloses the bag may not have been closed properly, or a part of the bag got caught in the seal of the case. Take the bag out and reinstall. Hope this helps!
Mar 12, 2010 | Vacuums
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Motor shaft getting really hot
Open up the area where the beater is with the belt off. Turn the beater by hand...if it turns hard, the bearings are jammed up with old grease or debris. You'll have to deal with that.
Nov 03, 2007 | Hoover Ultra U6430-900 WindTunnel Bagged...
Vacuums Logo
125 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
