My dvd ram is not work and no load anyware disc
    Scholar:
  • 69 Answers
Please perform the below steps :
Step 1 # Deleting UpperFilter and LowerFilter Registry Keys
Backing Up Registry and Registry Key:
CAUTION: The registry contains critical information and a
registry backup is essential. An incorrect registry
entry may cause serious system problems or prevent the
computer from starting. You will not be warned of any
incorrect registry entries. If the registry is not
backed up, the only way to recover the system is to
reinstall the operating system. Do not double-click the
Backup.reg file on the desktop unless you intend to undo
the changes you are making to the registry.
1. Click Start and type regedit in the text box.
2. Click "File" in the menu.
3. Click "Export" from the drop-down menu.
4. Click the down arrow beside "Save In" and select Local Disk(C:).
5. Type Backup.reg in the File Name field.
6. Click Save.
Step 2 # Deleting UpperFilter and LowerFilter Registry Keys:
1. Click Start and click Run.
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor and restart the computer.
The CD-ROM drive, DVD-ROM drive, or CD-ROM R/W drive should now appear in the My Computer window.
Step 3 # Uninstall CD/DVD drivers from Device Manager
1. Click Start, Control Panel, Device Manager.
2. This opens Device Manager.
3. Click "+" beside CD/DVD Device Category.
4. Right-click the listed CD/DVD/RW and select Uninstall.
5. Restart the system.
Windows will redetect the device on restart and reinstalls the drivers automatically.
I am sure this information helps you. Please reply if I can help you further. I would like to add that we value your precious time and would be here round the clock to serve you.
Posted on May 16, 2010
When attempting to record on a DVD-RAM disc the unit says that the disc is read only. This disc has been recorded on previously. Tried a new DVD-RAM disc with the same result
have you tried recording on a standare DVD disk, either DVD+R or RW or DVD-R/RW? if those don't work either, you have a bad recorder.
Mar 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
No Disc display
wrong reganal code most likely there are sites were you can unlock your dvd player (hack it) so it will play disks from anyware
Feb 17, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
No disc message appears when trying to record video. I am using dvd-r disc. not even sure if that's the right kind? The ram card works great when taking photos but can't seem to get the disc to work. any...
DONE SOME RESEARCH ON YOUR PROBLEM AND I THINK IT CAN BE SOLVED BY DOING THE FOLLOWING. SWITCH FROM THE PRESENT DVD-R FORMAT DISC TO EITHER DVD-RW OR THE BEST BET FOR YOUR CAMERA AND FOR VIDEO IS DVD-RAM FORMAT. THE DVD-RAM IS A HIGH CAPACITY FORMAT, UP TO 5.2 GIG AND A RANDOM ACCESS DISC, WHICH MEANS YOU CAN FIND THINGS MUCH FASTER! I THINK THIS SHOULD SOLVE YOUR PROBLEM. IF YOU NEED MORE HELP, REPLY TO: ARCLIGHT1217
Nov 14, 2008 | Video Cameras
Dvd-ram 4.7gb
DVD RAM discs don't need finalised, hence its not an available option.
They will play directly on other players -*** BUT*** ONLY DVD
RAM players.
Don't expect your RAM disc to play on a normal
DVD+/-RW DVD +/-R device. Its not going to happen unless the
device supports DVD RAM also. If it does, it will play your RAM
disc once you've finished recording in your own DVD RAM
recording unit. Pop it out of your unit, straight into the other, and
the jobs done.
Nov 02, 2007 | Panasonic DMR-ES10 DVD Recorder
Suddenly won't read discs
just try playin the lens cleaner disc....
Sep 18, 2007 | Panasonic DMR-ES10 DVD Recorder
Can I playback my movies on a DVD-ROM drive?
No, DVD-RAM disc recorded on the DVD Camcorder will not play back on every drive. Some of the new DVD-ROM drives designed to be compliant with the new DVD-RAM book2 standards will playback discs recorded on the DVD Camcorder. Many previous DVD-ROM drives on the market that came out before the DVD-RAM standard was released will not play back discs recorded on the DVD Camcorder. HITACHI manufactures DVD-ROM drives for some PC manufactures as OEM products. HITACHI model GD-7500 DVD-ROM has DVD-RAM read/write compatibility.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Are there any DVD players/recorders that will play back both DVD-RAM and DVD-R discs?
Yes. Although at the present time most DVD players only support DVD-R playback, Hitachi’s DVRF7U will play back both DVD-RAM and DVD-R discs. In addition, there is a growing number of affordably priced DVD-RAM players that support both of these formats. These devices make it very simple and convenient to enjoy the robust capabilities of re-writeable DVD-RAM discs.
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
