Question about Maytag Neptune FAV6800AW Top Load Washer
I have a hole in the disk spinner? It is golf ball size. Where can I get a replacement part and do you know the part number? Can I use the washer as is until I get the replacement part?
  • 526 Answers
I assume your machine is a FAV6800A or FAV9800A and we are talking about the tumbler or Wash Plate as it is also called of those machines.
There is Left and Right version of the tumblers. You will have to remove the tumbler (see page 37 of the Service Manual for Tumbler Removal) and see if you can ID if it’s a left or right side tumbler.
You will need a Torx #20 driver to remove the Service Manual doesn’t call that out. Then you can ID which tumbler needs to be replaced. The left and right side markings are on the inside of the Tumbler/Wash Plate.
The Service Manual for reference. Sears Parts Direct for reference.
I would check Ebay you can take a look at a site like Sears Parts Direct in the above link also for a replacement.
The p/n’s that I found at searspartsdirect.com = 12002203 I believe is the Right Side and 12002204 Left Side but make sure you check the marking as to R or L as the Service Manual indicates. Also check with the parts supplier for proper replacement p/n.
“”Can I use the washer as is until I get the replacement part?”” I would be concerned about damage to the wash load if part of the wash load gets snagged on the edges of the hole.
Any idea how that happned?.........Rich
Posted on May 17, 2010
Why are golf balls numbered?
Golf Balls are numbered in order for golfers to be able to distinguish between their ball from other balls of the same brand. You can imagine how many golf balls could be lost in the woods; numbering them helps to find the ball that you hit and not the balls of the other six people that thought they were good enough to smack a four dollar Titleist Pro V1 around the course.
This being said, it is common practice to create distinguishing marks on your ball at the tee box with a permanent marker. I always thought that this was so that it wouldn't be so easy for your buddy to drop the next ball from the sleeve of balls he has (which all have the same number), claiming he miraculously "found" his ball sitting up nicely in the semi-rough just over the hill in front of you. Although there are obvious ways around this, so maybe its just to display some creative artwork skills before the round.
May 29, 2018 | Golf
Can a golf ball be replace by a different type of ball during tournement play
"There is nothing in the Rules of Golf that prevents a golfer from switching to a different brand of golf ball (i.e., from a Titleist to a Bridgestone) on every hole on the course - so long as the change is made between the play of holes.
However, there is something in the Rules of Golf that says a tournament committee can impose such a rule.
It's called the "one ball condition" (in the rulebook, it's in Appendix 1, Part C), more commonly known as the "one ball rule." As you probably know, all Tour events are played under the "one ball rule." And any rules committee may adopt the "one ball rule" for its competitions.
"The "one ball condition" requires the player to use the exact same brand and type of ball throughout the round. For example, if you tee off the first hole with a Titleist Pro V1x, then that's what you must play throughout the round. You may not switch to any other brand of ball, nor even to any other type of Titleist ball. You started with the Pro V1x, so the Pro V1x is what you must use on every stroke. "If the "one ball rule" is not in effect, however, golfers may swap out different types of golf balls at any point in a round of golf, so long as the change is made between holes rather than during the play of a hole."
Aug 25, 2014 | Golf
I want to know how many dimpels they are on a golf ball
The rules do not specify the number of dimples. A golf ball typically has from 250 to 450 dimples.
Aug 28, 2013 | Computers & Internet
I want to know how many dimpels are they on a golf ball
There is no rule specifying the number of dimples. A golf ball typically has from 250 to 450 dimples.
Aug 26, 2013 | Computers & Internet
My InSinkErator Badger1 garbage disposal has started leaking from a small hole (round, ~1/8") about 2/3 of the way up the back of the case. It's particularly messy when the disposal is running. Is this...
Your drain is probably OK. The disposal is going bad. You can temporarily repair the disposal by using plumber's epoxy putty ( found at most home centers for about 5 bucks) to seal the hole. Sand the area around the hole first, and then dust it off. Use about a golf-ball size section of putty to seal the hole. This is not a permanent fix, but it will get you by for a while. Replacing the garbage disposal will be the ultimate fix.
If after repairing the hole the sink stands full of water, then you know for sure that the drain is backed up.
Sep 09, 2010 | Plumbing
How do I remove the piston on a 1957 Chev Belair power steering cylinder?
YOU HAVE TO REMOVE UNIT FROM CAR.REMOVE THE CONTROL VALVE ASSEMBLY AND THE ACTUATING LEVER.REMOVE THE PITMAN ARM SHAFT ASSEMBLY.REMOVE THE CAP SCREWS HOLDING THE UPPER END COVER TO THE HOUSING AND REMOVE THE END COVER.USE A SMALL PUNCH OR SCREWDRIVER TO REMOVE THE OIL SEAL FROM THE COVER BE CAREFUL OF THE NEEDLE BEARING.NOTE THAT IDENTIFICATION NUMBER OF THE BEARING IS INSTALLED TO THE OUTSIDE OF THE COVER.PULL THE RACK PISTON BALL NUT AND THE WORM ASSEMBLY FROM THE HOUSING.REMOVE THE PISTON RINGS FROM THE PISTON REMOVE THE BALL NUT RETAINING SCREW. TURN THE RETAINING SCREW HOLE DOWN SO THAT THE BALLS AND THEIR GUIDE DO NOT DROP OUT AND SLIDE THE BALL NUT AND WORM ASSEMBLY OUT OF THE RACK PISTON.REMOVE THE BALL GUIDE FROM THE NUT AND TURN THE HOLES DOWN.THEN TURN THE WORM BACK AND FORTH UNTIL ALL THE BALLS HAVE BEEN CAUGHT ON A CLEAN CLOTH.THERE ARE 23 BALLS.THEY HAVE A DEFINITE SIZE AND MUST BE REPLACED AS A SET.THEIR SIZE IS STAMPED ON THE END OF THE BALL NUT.REMOVE THE BALL NUT AND ADAPTER FROM THE WORM.REMOVE THE RETAINING RING WASHER AND SEAL.FROM THE NUT SIDE OF THE ADAPTER.CHECK OVER THE BALL RETURN GUIDES AND CLIPS THE RACK PISTON THE BALL NUT AND THE WORM.THE WORM AND BALL NUT ARE A MATCHED ASSEMBLY IF ONE IS DAMAGED BOTH MUST BE REPLACED WITH A NEW SET.DO NOT DISTURB THE END PLUG IN THE RACK PISTON UNLESS IT IS LOOSE.IT CAN BE DRIVEN OUT FROM THE INSIDE OF THE RACK PISTON.STAKE THE NEW ONE IN PLACE AT FOUR POINTS.THE END PLUG IN THE HOUSING IS DRIVEN TO THE OUTSIDE BUT IS INSTALLED FROM THE INSIDE.IT SHOULD ALSO BE STAKED AT FOUR POINTS.
May 04, 2010 | Chevrolet Chevy Cars & Trucks
The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
May 12, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Maytag Neptune FAV6800AW Top Load Washer Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
