Question about GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
GE Profile french door refrig not cooling but freezer is cold
3 years old, freezer is cold but fridge will not cool below 55.
  • GE Master
  • 4,655 Answers
Look into rear of freezer and see if a layer of frost is building on rear panel. If yes you will need unplug and manually defrost with a hair dryer. That will help speed things up. You will also need the correct model number to get the correct parts. The odds are the defrost heater is defective. Because cold air is heavier than warm it tends to settle to bottom freezer making it appear OK. If there is no frost in freezer rear wall then we would look for the air supply damper to be closed between compartments. Look and see what you are going to need do and I will look up the parts assuming your model is a PFSF5NJXBB I will return soon, Thanks, Sea Breeze
Posted on May 16, 2010
  • John Tripp
    John Tripp May 16, 2010
    Depending on model number the defrost heater is part number Click Here=> WR51X10094 Click Here for location of model numbers=> Appliance Model Number Locations If you replace the defrost heater it would not hurt to change the defrost thermostat part Number=> WR50X10069 both links have no photos. If not defrosting remove the rear freezer panel after unplugging. Defrost evaporator with hair dryer until you can get a good look at defrost heater. If burned out it will be easy to spot because the defrost element is inside a glass tube. Burn out usually makes blackened glass. It will not hurt to examine fan as appliance mentioned. They are12 volt DC fans and have been known to go bad. Let me know what you find. I will be here if you should respond. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Thanks, Sea Breeze
    President:
  • 2,468 Answers
Your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
Refrig will not get cold freezer is fine, fan was sounding very loud last week but it stopped making the loud noise n the refrig seemed fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 25, 2011 | Samsung RF265AA Bottom Freezer French Door...
My ge side by side profile tps24 is not cooling on the refrig side and the body of the refrig is hot. Any ideas?
heatman101
May 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile 25.1 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
596 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
